This customer and member sent me two intakes to port (hopefully he steps in). He will be running a TrickFlow head and luck I just happen to have a set so I did a flow test to get some numbers on number 8 port. That runner had numbers backing up terrible so I unbolted the head and switched over to runner number 6. Although not the best it didn’t go crazy turbulent like the other runner. He wanted the Victor340 done first so the RPM testing will be later. First off some good and bad news. If you remember the new Victor340 that I ported a few weeks ago had every single hole off around .115 so I had to egg shape the holes. Well this intake is new but ordered months ago and the holes are perfect. Pictures show the Superformance Gasket he uses and the gasket I use on my stuff and most of my customers. His gasket is about a perfect match on the TrickFlow head too. I will be hitting this hard tomorrow hopefully but here are some before and after pictures and flow numbers. Oh he had a plastic 1/2 thick spacer that I won’t be able to use because it’s hollow underneath. Guys if you use a spacer and want to blend it spend a few bucks extra for a one inch solid aluminum one. This intake will be tested without a spacer.
