New tires and carb rebuild.
Nice fix . . On the Car !First time using Ez-LOKs. Couple things I learned. The thread locker compound is ****. It made it so hard to thread the lok that I stripped the notches. Once I removed it and added fresh red thread locker it went in easy. Flushed it to the head and it barely looks repaired. Now to clean up, gasket, and button it up. I gotta say these ez-loks seem way more solid than Helicoils.
View attachment 1715343162 View attachment 1715343163 View attachment 1715343164 View attachment 1715343165 View attachment 1715343166 View attachment 1715343167
Here is a Great Solution for peanuts in cost.
Had the same crappy running, gas leaking fire hazzard of a 2 bbl carb on my 69 318. Swapped it out to an Edlebrock 1406 using this 20.00 4 bbl adapter that you can get through AdvanceAutoParts, using the same stock 2 bbl intake manifold that came factory on the car.
You will see here that the 4 mount holes to your 2 barrel manifold have been machined down with a tool on your drill press. This gives enough clearance so the carb butterflies don't hit the mounting bolt heads. You can mount the 4 bbl carb directly to this without a spacer plate.
'69 318 stock 2 bbl intake manifold with Mr. Gasket 4 bbl adapter.
Easy 25 horse power upgrade, runs so nice, starts great with electric choke, and you have the secondaries to play with for more performance.
Makes a whole new car out of it, and don't have to change the intake manifold or camshaft.
It really Pulls, I am very impressed . . . 273s are Great Engines too, It gives the engine the fuel that it needs !
You will need this Edelbrock Mopar Bracket # 1481 to hook up your throttle cable to the carb in the correct geometry. It puts things in place if you have the automatic kickdown also.
Just add the Carb and you are good to go.
Enjoy, happy sailing . . .
I finally disabled the cruise controll on the duster...and by that I mean I replaced the sticky throttle cable with a brand spanky new lokar version
Yes and no...i got it adjusted to the point where the pedal will bottom out about 1/32nd short of opening to WOT (that way, there is no extreme pull on my throttle cable when I gun it, but all the power is there)Does your cable open your carburetor all the way to WOT? I am having a hell of a time getting mine to open the carburetor all the way, with my pedal running out of travel by about an inch.
If you're having issues the first thing to check is pedal movement
Is there anything keeping the pedal from going all the way down, or all the way back
If that is clear, check for adjustment in the cable itself (if it is stock, you can adjust the outer sleeve where it mounts to the engine)
Finally check to see if you have the correct linkage on the carb
Worst case scenario you can move the connecting point on the throttle arm closer to the shaft, changing the geometry and fixing if that way
Toss some pictures up of the engine and who knows, we may spot something obvious that you're simply overlooking
The D100-440 is alive. I would post a video but I don’t have account anywhere. I got everything on my list done yesterday. I’m off tomorrow and I’m starting on the exhaust. I have to figure out where to put mufflers, H-pipe, and dump the exhaust. I think I’m going with a turbo instead of chambered. I didn’t much care for the Flowmaster 40s on my Dart. Too much drone noise. I’m hoping behind the rear tires but, the truck is lowered and I may have clearance issues over the axle.
If the issue is in the pedal, I would suggest pulling it out, heating it up, and putting a little more bend in it
But let's look at the pictures first
So what I was planning on was grabbing a piece of 3/4" angle iron and welding it to the bottom of the pedal mount bracket to give it the amount of swing room it needs. I had wedged a 3/4" thick piece of wood behind it and it worked correctly. The angle iron at the bottom would give it a stable perch that rests on the floor and would prevent it from losing its bend again.If the issue is in the pedal, I would suggest pulling it out, heating it up, and putting a little more bend in it
Scraping the under coat off the inner fenders.... well that's how the day started at least....
4 or 5 pounds of under coat off each inner fender and headlight bucket.
Painted with rustolem hammertone black, brush on.
Almost done with the passenger side.
That's when it all went bad...
Pops was giving me **** about the old plasma cuts on the tilt front end. I said if it bothers you so much grab a grinder and clean it up!
Well he did, what I didn't see was him cutting the strut rod that holds the tilt from swinging. He cut that rod and the entire front end let go, folded the something in the front and now it wont close....
The big MOPAR show is this Sunday and now my front end wont close....
I'm supposed to be finishing up a customers supercharged mustang but I'm gonna try and sneak some time in to figure out what got bent. Worst case I just work all night Saturday..
