Buy a heavy duty billet spring retainer ($25). ...lol
I blew out 2 stock units....
Jeff
I remember reading about those!! I'll order one!!
Jeff
Been there several times. I put an x pipe on my car and it was well worth it. The sound is awesome! Your gonna love it. I put 2-1/2" out the back with 1' thrush glass pacs. Might as well be open headers. Lucky my neighbors don't give a crap.the new exhaust is an X pipe, fully welded so it would be tricky to only install one
so for now, im running open header (sorry neighbors)
these are 2.5s into a set of stainless pypes mufflers which dont look much wider then glaspacks and they dump just before the rear axlesBeen there several times. I put an x pipe on my car and it was well worth it. The sound is awesome! Your gonna love it. I put 2-1/2" out the back with 1' thrush glass pacs. Might as well be open headers. Lucky my neighbors don't give a crap.
My cheap *** harbor freight transmission jack did the same thing the second time I was doing a test fit of my A500. I looked at the booklet that came with the jack, and there were instructions on how to bleed the jack (actually I think it said to do this before use, which I didn't). After bleeding it, it worked just fine.Well I didn't get as much done today as I wanted to. My cheap *** Harbor Freight transmission jack decided to stop working 3 inches from the height I needed it to go so I returned it exchanged it and got another one, and the transmission is bolted in. I just have a few more connections and the drive shaft and I can put it on the ground tomorrow and I think I'll be able to take it for a test drive on Sunday like I thought.....fun day!
Jeff
You read the instructions? ???????My cheap *** harbor freight transmission jack did the same thing the second time I was doing a test fit of my A500. I looked at the booklet that came with the jack, and there were instructions on how to bleed the jack (actually I think it said to do this before use, which I didn't). After bleeding it, it worked just fine.
View attachment 1715487163 Starting to run 1/2 inch fuel line for the sniper efi. That is a Holley filter/regulator that is preset to 59.5 psi so only one line needs to go to the front. View attachment 1715487161View attachment 1715487162
Watched it rain the entire day, so the car sat in the garage
