72Dart6pack
Harder Better Faster Stronger.
I got mine from DTM and had no issues.
Nasty stuff to try and get off took weeks to get that stuff off my arms and face .Finished cleaning up the back half of the undercarriage and got some por15 on it. Eventually it will wear out of my hair and everywhere else it decided to drip on View attachment 1715530470
Not sure if you guys care to hear about non A body mopars, but This is also on FCBO.
Got my 66 fury started (only for a minute) and learned more about it.
The car was parked in 1998 (I remember seeing this car when I was in high school in the early 2000s) and it sat in the same spot until I cut all the trees around it and dug it out in August of 2018.
I greased each cylinder and pulled the distibutor and turned the oil pump for 10 minutes with a drill the evening before I attempted to turn the engine.
I connected a battery and DEAD
Replaced the battery cables and ran a hot wire to the coil .... DEAD.
replaced the starter and it fired but I couldn't keep it running and the carb gushed gas everywhere.
At least i know it's a good poly, sounded good for the minute.
2020 has been a good year for me so far because the wenches have been turning non stop. I'm making up for 2018 and 2019 being wasted years with nothing on cars moving.
Replaced the mp valve covers with oem type installed my ld340 I bought from a member hereView attachment 1715530315
Yes it is. Came out of my hair fairly easy but I could only stand so much scrubbing to get the rest off. It will wear off sooner or later. SEM makes one similar that I have used that is a bit thicker and doesn't run as bad but I ran out of that. It was also more of a flat blackNasty stuff to try and get off took weeks to get that stuff off my arms and face .
Probably had a leaky heater/heater coreWire wheeled the floors in the demon to eliminate any scale rust.
Then applied rust Mort. It turned the rust black. Now I wait to primer it.
I found more pinholes on the passenger side but strange it turned out to be completely solid on the driver side.
