What Are You Doing To/With Your Car Today?
Follow- on... cleaning it all up and cruising today allowed for a better understanding of fluid weak points.
In a nutshell seems primary gaskets are showing their age. Head, oil pan, transmission fluid pan seem to be suspect. Some just getting moist up to drip forming but not actively dripping. Nothing hyper critical.
Adding to the winter work checklist
Over the weekend I fixed the Dart's charging system. Recently the ammeter was registering a slight drain with no movement as RPM's increased. I had rebuilt the alternator last October so I'm thinking its just worn out. I teed up a PowerMaster alternator on Summit but before pulling the trigger I opened the hood and began testing with my voltmeter and found the problem.
So how did I fix it? Simply plugged the green field wire back into the alternator. It had worked its way out and was hanging by a thread.
Kinda at a stand still on my dart until I get some parts I ordered so im working on my ram project. Got the front bumper back on and im working on getting the bed off now taking a quick break to cool off.
Lol....
Awesome!
Jeff
Last Monday after work I had an unexpected contact with a manhole cover. I had come over a slight rise and a railroad crossing, when I came over the rails and down my transmission pan slammed into the manhole cover. It is slightly elevated from the pavement, maybe an inch or so. Damned if the car didn't start to shake the crap out of itself. I was going slow, no more than about 25 mph. I pulled over and took a look under the car, nothing was leaking, no crunched headers, so I got back in and tried to drive it, was ok under 15 mph, but started shaking like hell at anything more. I limped it home on side streets and put it on the hoist.
Pretty much a direct hit on the trans pan, and somehow blew out one of the u-joint cups. Could have been a lot worse, I think I was lucky. Got a new u-joint put in tonight and it's back up and running again. Took a good long road test, smooth and solid again. Might have one more week or so to put some more miles on the old shitbox before I park it.
Got the bed off new shocks installed and cleaned and painted the frame. While the bed is off im gonna replace the cab corners and rockers im trying to decide if I want to paint the whole truck or just rattle can the bed and patch work.
I got the clutch disk prepared the other day,I run an iron disk and they chatter until you ware the square edges off the pads.But if you dress the square edges on those pads before you use the disk it has no chatter...
i got a call from one of my friends, said he needed a favor
(he's been courting this girl for a while and wants to take her somewhere special)
so, i aired up the tires and shocks, made sure everything is on the up and up and now im waiting for him to come grab it
yeah, i know, the duster has about 3 decades on him
i dont mind, its a just a car
Well, just got the car back, topped off, vacuumed and with a $40.00 gift card sitting in the cupholder
Damn, could have been a lot worse. I remember my daughter knocked a big hole in her oil pan and drove it till it locked up. :BangHead:
Well I finally got the engine back in,I had to freshen up the carb.I changed the cam in the engine and put a smaller one in which took 8 degrees of intake duration out. So it needed to have some jet taken out.So everything is fresh once again.
View attachment 1715802376 View attachment 1715802378 View attachment 1715802379 View attachment 1715802380
@Rob R
I see you're running braided fuel line from the tank to the front. ...
I need to run new lines because I'm adding fuel injection and a pump in tank....
No problems running braided line?
Seems a little easier. ..
Jeff
Jeff
That fuel system has been on the car since the very early 90's.Not one problem with those lines, I've gone through 3 fuel pumps and not one problem with any of the lines.
missing...
Thanks,Ive owned it for 46 years.Every car I own is like the GTX.I like every part of the car to be a little over restored,it helps when I work on them it makes feel better when I have to do what ever repair they might need.I hate working on them,that's why I only buy the very best parts so maybe they might last a little longer so I won't have to fix anything:lol:
Jeff
Thanks!
I'll still have to run new hard brake lines, but the fuel lines will be easier!
I have to move my brake and fuel lines to install my subframe connectors. ......
Jeff
Thanks!
Jeff
Are this bought connectors?
I build mine and only had to move the park brake cable
Finally got the backside of my trunk lid painted.I set up an old screen tent outside the garage and painted it in there.saved me wrapping the garage in plastic.Turned out decent and no bugs!!
