b s , as in total !yeah use synthetic in flat tappet motors. Say goodbye to your lifters when they quit spinnin.
b s , as in total !
I like mint chocolate chip and banana ice cream :happy1:This thread is exactly why I don't post in threads like this (usually).
I have not seen a single comment where oil was dyno tested, correct evaluated and then compared to another oil. Why is that? Because it in farking expensive to test oil correctly. To test an oil against just one other oil takes 30-40 dyno pulls, at least 3 (sometimes 6) oil changes (if the data is unexpected) or more, the cost of analysis, then, disassemble and measure component wear.
So let me say this about the 6 different oils I have tested. Dino oil is usless in a performance engine. I don't care how often you change it. Synthetic oils do not stop lifter rotation, any more than they stop roller lifters from rolling. Total crapola. If using flat type lifters you MUST have ZINC. PERIOD.
As for cost, the bottom synthetic oils are worth slightly more HP over dino oils. The mid priced sythetic oils are a waste of money. The uber expensive oils (such as Torco and LAT) are worth every red cent. They out perform every other oil in testing and after dyno results (there are a couple more in the uber class that are good too).
Do what you want, but asking a forum what oil they like is akin to asking what ice cram is better, chocolate or vanilla. It's mostly just opinion or taste.
FWIW, mocha almond fudge is the best ice cram.
Sure, you can call it BS, still won't help with your camshaft warranty claim. If I built an engine for you and supplied you with a break in oil and then you decided to use your own synthetic, and had a failure, then you wouldn't be getting a sympathetic ear from me.b s , as in total !
Just like taking stock in what oil companies say is best is like listening to a crack dealer.
I am still trying to figure out why/how a synthetic oil could stop lifter rotation.... As I understand it, lifter rotation comes from the lifter's contact point with the cam being off of the center of the lifter axis.....can't think of anything else that causes it. How can a synthetic change the point of contact? And if it reduces the turning friction between lifter and lobe, it also reduces the drag trying to prevent rotation at the pushrod contact at the rocker and lifter.
Crane and Crower and Lunati don't want you to use synthetics 'during break-in'. Comp does not seem to care and says their break-in additive is compatible with synthetics. I have not personally had any issues with synthetics and have raced on them a lot with excellent results (in harsh endurance racing: rallying). But, I have never seen any real degree of wear reduction on cams/lifters with synthetics similar to what is consistently found on rings/pistons/bores and on bearings/journals.
That bypasses the question about idea that synthetic will actually stop lifter rotation.... I would like to understand this issue, rather than just blindly accept it.There is no point wondering about the "why" if they won't warrant a failure.
