So with that in mind does that change the hp rating people are giving? Or still the same.Those are good heads and have the best exhaust runner for LA style heads.
Not really . Not without working the intake side to flow better to match.So with that in mind does that change the hp rating people are giving? Or still the same.
ThanksNot really . Not without working the intake side to flow better to match.
Here's mods to a stock 360 short block you should be 340-350hp.
I might have to look into that!That holdener video is very good on what can be done. Pretty realistic numbers for the build. The biggest gain was in the porting, no doubt, jumping 60hp with the small cam swap.
Right about in line with the 1.1hp/ci on a good tune up.
Congratulations on getting your feet wet.
Yeah I had to put my feet into the bath salts of engine building lolFeet?
Well I have 2 kids so I've been there done that. I've done everything else to a car except build an engine and build a transmission. Well the transmission will never happen. Because I will buy the sst tkx kit. But it was nice to build a engine without taking anything to a machine shop.Times are different now I guess. Us old timers used to get something else wet when losing virginity.
If they are shot absolutely replace them.I found out after this this video was made i pulled the valve covers and found all my valve seals are shot so those are all on order.
Surely you can’t be serious? He said they’re shot. If they’re shot you replace them. Unless you enjoy driving around and after every stop you marvel at the clouds of oil smoke at startup.The valve seals? Hogwash! You're wasting your time with seals.
They are so shot the valve seals come off the seat and ride up the valve. After a minute of start up. Looked down one cylinder and the whole top of the piston was covered in oil.If they are shot absolutely replace them.
Well, I “assume” they are factory style seals? where the intakes should fit snug onto the guides and stay put while the exhaust seals float. When you say Shot, to me that means they would be hardened and/or all broken up in pieces. Were the heads rebuilt, refurbished? New valve guides (or actually liners) installed, or were they knurled?They are so shot the valve seals come off the seat and ride up the valve. After a minute of start up. Looked down one cylinder and the whole top of the piston was covered in oil.
They are the factory seals. Most of them are pretty hardWell, I “assume” they are factory style seals? where the intakes should fit snug onto the guides and stay put while the exhaust seals float. When you say Shot, to me that means they would be hardened and/or all broken up in pieces. Were the heads rebuilt, refurbished? New valve guides (or actually liners) installed, or were they knurled?
3.55 gears are in the car now. 25 inch tall tire. 235sWhat is the gear ratio and the planned tire size?
235/60/14?3.55 gears are in the car now. 25 inch tall tire. 235s
235/50zr17 raptor zr a/s tires235/60/14?
Right now the way I have it setup my airfuel ratio gauge goes from 13.5 -13.2 at idle and about 13.8- 13.5 revving it. So the fuel trim looks good. I don't have to pump the carb to fire it up cold or hot. So timing is pretty good also.The tune will be about as important as the combo ......
maybe..... you won't know till it's in the car and you can drive it. Then, you let the engine decide where it's happy. Run stands, AFR, and the such are just tools. When the engine is in the car and under load, THAT is where the tuning begins. All else is just ball park.Right now the way I have it setup my airfuel ratio gauge goes from 13.5 -13.2 at idle and about 13.8- 13.5 revving it. So the fuel trim looks good. I don't have to pump the carb to fire it up cold or hot. So timing is pretty good also.
Agree. It's going to be a bit for that that sst tremic kit ain't cheap. So will have to save up for that.maybe..... you won't know till it's in the car and you can drive it. Then, you let the engine decide where it's happy. Run stands, AFR, and the such are just tools. When the engine is in the car and under load, THAT is where the tuning begins. All else is just ball park.
