What does the distributor look like? Can you post a pic?
What does the distributor look like? Can you post a pic?[/QUOTE
Sorry, no picture of it.
The distributor is the Mopar Performance one that was based on Mallorys unit. It was bought in 2003. In 2005 I had a guy at a dyno shop work on the car. He shortened the advance range to 14 degrees. I used to set the initial at 17 with full advance topping out at 31 degrees. I used to run vacuum advance put plugged it to stop the knocking.
