roccodart440
- Joined
- Apr 19, 2010
- Messages
- 6,895
- Reaction score
- 3,718
Then again, if it works, leave it alone
Can't dispute that tried and true theory.
That's why my factory shifter is still in the factory console.
Old school isn't always bad. Technology and product availability has come along way since the 1960's. I'm just for taking advantage of the worthwhile improvements.
If you don't want a crossover, H or X, then don't run one. Simple.
Old school reminds me of the guy in my town who swears by his Mallory dual points, his thermoquad, his flex fan, his tiny rappy exhaust and his .509 cam. He gets his *** mopped and leaves the car home on hot days. He talks down on mine because I use new stuff that either isn't as good as the old stuff or ruined the car for taking the factory stuff off.
Back in the late 80's the '71 340 4 speed 'Cuda I had ran 12.5's on street tires with a mechanical tach drive Mallory dual point, a .509 cam, 2.5" dual with generic turbo mufflers and a thermoquad with an adapter on a Tarantula intake. It ran a flex fan and never overheated.
It worked for me... View attachment 1714990088
Yup, and I see many 408's out there, with the RPM air gap, Holley carb, MSD junk blah blah blah that run the same or not much better. And you did it with street tires that are nothing like we have today.
I'd run a Mallory dual point long before I ever used the Chrysler OE electronic ignition.
The .509 cam is better than 90% of the dual pattern junk I see some people use.
The Thermoquad is highly UNDRRATED.
I use a flex fan. My **** don't overheat. In the desert.
Someone posted a link to a great article on cams in the thread on camshaft th engine section. You ought to click on the link and read it. You may learn something.
What you think is old school really has zero to do with its practicality or how it works in combination with other parts.
ITS THE SYSTEM, THE SUM OF THE PARTS. Not individual parts.
This is about a X-pipe vs. an H pipe. To which you didn't like my original answer because I pointed out the guys dislike mostly stems from his being "old school" AND because you love to pick a fight. That's pretty clearly be established.
I'm glad your stuff works.
I run all the stuff you hate. MSD, Holley, RPM intake, H pipe.
I don't run a dual pattern cam but I do run a 112 LSA cam so I know it's "a dog" "junk" "wrong". Well I can tell you compared to when I ran the .509 cam it is faster and more street friendly so to me that's a win/win
You don't even know me, who I am, what I do. But let me introduce myself. I'm an industrial arts professor with a long vested interest land transportation and construction systems. I work as a freelance personal trainer. I hold 6 NYS powerlifting records and in 2009 held a world record. I own my own general contracting business. I own, operate and race a circle track car, a street/strip car, and a motorcycle. I've built a handful of cars. Oh, and I've even been paid to work on a few people's cars over the years.
Now that you know a little about who I actually am..
An X or H pipe "jacks the car up"?
My stuff is "jacked up".. ?
Laughable. My stuff is functional, show winning and race winning. Proof is in the winners circle, street time and show trophies.
20 years ago, your comment would be appropriate. You aren't fixing anything I jack up. Nothing.
To the OP, if you want an H or X pipe run one. It changes the sound of the car and may or may not improve the performance. It certainly won't hurt anything.
Ok, after doing a little more reading, I think I will put in the H pipe.
Thanks for the input.
Likely you will find as a best case scenario that you won't find anything except a lighter wallet.
Yellow: as I said, ”one test is worth ß thousand opinions "
It's kinda like chicken soup, were not sure it helps but it can't hurt.
I appreciate the old school knowledge, I also appreciate the new school. I am deep in electronics, it helps with the testing part of things.
Seems some of this gets personal, it's not.
All I can say is I respect and appreciate the input. I really do. I'm an old guy, that is how and why I respect and appreciate others opinions.
Dyno? Why would I not put it on a dyno. This thing is going on the dyno no matter what. Testing is what I do.
One more time "one test is worth a thousand opinions".
Opinions aren't worth ****.
Gentlemen, although I do respect y'all's opinion, it has been proven time and time again on dynos that when paired with a tornado air management device, that X and H pipes both show massive gains.
How much can a foot of pipe and five minutes of welding really cost? Putting in an X/H pipe in is not going to break any wallets.
A long time ago,2004,I put a GearVendor unit behind the A-833 in my 68 Barracuda 367. In the process I had to cut out the H in my TTI dual 3s.
If the car is consistent there is nothing wrong with the dragstrip dyno. Not to mention it's cheaper and more fun.
