dartfreak75
Restore it, Dont part it!
So this piece?I think your right. That back part is a rear footwell or intermediate pan.
It has been sitting for a very long time. It sat for a long time when I bought it in 2001 I think it set from 1993 till 2001 then I drove it till 2004 and it's been parked since. The front passenger side floor and the front frame rail was rotten when I bought it in 2001 I replaced the floor and fixed the frame back then I never took all that jute padding outbid the back until the other day I had no idea it was rotten like that back there it could have been like that back then and I never knew it.If water comes in and it never drys it will wick through the jute padding and spread all over. It typically doesnt make it to the rear pans but can if your leak(s) are bad enough or the car is sitting for a long time.
I have been chasing a ghost leak on my 73 dart sport for a year. I have found several leaks but its still getting in somewhere. I probably wont find the real leak until I get this stripped and on the rotiserie. I ordered the one piece floor pan for it. Both of my fronts are totally shot.
I would appreciate that buddy.I have used the small floor pan patch panels before. In most cases thats all you need. In your case it would be an economical way to do the bulk of the repair and it will leave you less to fabricate.
I can look and see if I saved the hump part of the 71 dart I parted last year.
Southwest vaMy dart sport floors are rotten and I have about 1500 daily driver miles on it. I just slapped some duct tape on it until I get around to restoring it. I just ordered ALL the sheetmetal to finish the car the right way.
What part of VA you in?
I dont either lol thank you very much I appreciate it.I wrote myself a note to take a look tomorrow. I dont reall the condition of it. If it was usable I saved it. I dont throw anything away.
Thank you buddy I appreciate your help.What ever you decide to do good luck with your floor repair.
Worked in my 74 Scamp. Should work fine. By the time your $130 into ill-fitting front and rear patch panels you get this for $200 and you don't have to re fab the seat mount. It's one way you could go.Ok thanks guys I really appreciate it. I have a couple questions. Did anything change dimensionally from 74 to 75 I cant find anything for 75 everything stops at 74. I'm pretty sure nothing changes from 74-76 in swingers and scamps? This is the whole passenger side floor full length and it says it goes from the rocker to half way to the hump will this work? Even tho it says 74?
Yup.
So in your opinion I should just buy the panels and not try to fab them?Worked in my 74 Scamp. Should work fine. By the time your $130 into ill-fitting front and rear patch panels you get this for $200 and you don't have to re fab the seat mount. It's one way you could go.
Naw. To each his own. You know what I did. At my age it was right for me. I know you like a challenge. It was more than I wanted to tackle.So in your opinion I should just buy the panels and not try to fab them?
Here is my biggest concerns with the panels one I know its gonna be a challenge to get it out correctly to get a new one in right. For the floorpan and the rear foot pan its 302 dollars that I really dont have so its gonna have to wait it will put me that much farther behind lol. And lastly what if the half pan dont go far enough up on the hump to weld to like blu said? That's gonna be alot of money then I still gonna have to fab something anyway I'm doing a side job right now for a guy he is paying me 250 bucks that money was supposed to go to the machinist but technically I could use it for the floor pans but then I'm gonna have to wait longer on my engine. this is never gonna end is it? Haha it seems like everything i do on this car ends up being a speed bumpNaw. To each his own. You know what I did. At my age it was right for me. I know you like a challenge. It was more than I wanted to tackle.
Anyone that repairs metal with fiberglass should have their car confiscated. Sorry, that's the damn truth. It will make the rust WORSE. It will speed up the decay of the remaining metal. You're also not going to be able to combine the two in a way that will maintain the structural capabilities of the unibody chassis, I don't care how clean you make it. The fact that you go out of your way to say it's a temporary fix and not to take passengers indicates you already know you're giving terrible advice that will compromise the integrity and safety of the car.
If you find yourself seriously considering repairing metal with fiberglass, it means you're in over your head and do not have the skills to make the needed repairs. Walk away and take it to someone that can do it right before you screw it up worse. Hell, the fiberglass isn't really even cheaper than plain old sheet metal, so all it really shows is that you lack the skills to carry out the repair. It's just a waste of time, money, and effort. In a very short period of time you'll have to do it all again, and if you didn't have the money to fix it right the first time how are you going to have the money to do it twice? Especially when the second repair will be more extensive than the first because the first repair did even more damage than was already there?
Yeah, the best way to do it is to buy a full pan. Not only that, it's probably the easiest way to do it too. It definitely takes less time and welding than if you start making small patches and welding them in. Yes, plain old sheet metal is cheaper in up front costs, but don't forget that you're going to need a lot more welding rod/wire and gas to make the repair happen. The spot welds to replace the full panel take very little filler material and a ton less weld time. Considering the entire repair, if you have to buy and extra tank of gas and another spool of wire how much did you really save vs a full panel? What's your time worth?
If the full pan replacement is off the table then j par lays it out well. You want to make the patches as large as you can without making the bending of the panel too complicated for a single patch. The smaller you make the repair sections the more weld you're going to have to lay out. The more weld length you have to share with old metal the harder it will be, because more than likely you'll want to make the patches smaller than they really need to be and you'll end up welding to metal that isn't perfect. Which makes the welding a ton harder. I've made my own share of patches, and the more I do it the more I agree with replacing entire panels. It may seem harder, but when you really start considering the time, effort and amount of welding to make and install smaller patches it tips the scales.
I'm not a factory correct restoration guy, I'm also a guy that doesn't care if it looks perfectly original as long as it's structurally sound. But honestly, if you're gonna replace more than about 25% of any given panel, you're time, effort and ultimately money ahead to do the whole panel. It costs more up front, but in the long run when you consider time and materials it's easy to end up piecemeal'ing your way into spending more money in the long run. Been there, done that.
Well, like I said, some heads were gonna explode...
Looks like the MOPAR Police are on the scene, Officer 72bluNblu reporting for duty!
First off, "Anyone that repairs metal with fiberglass should have their car confiscated" is just a super D-bag statement. Do you have any idea that there are people out there that can't throw $100 bills around to fix their cars? I bet if you took a poll to see how many FABO members have made a fiberglass repair back in the day, you'd get a whole bunch of guys saying "Yep, I sure did".
Second, "It will speed up the decay of the remaining metal" is just a fear statement. Perhaps you missed the part where I laid out some advice for the OP to put money away every month until he has enough for a replacement pan in a year? Are you really proposing that adding fiberglass will cause such catastrophic decay to the surrounding floor pan, in 12 months, that the car could not be saved? Carbon steel corrosion occurs when the relative humidity of the air is 70% to 80%. These conditions are met or exceeded in Virginia (which is where the OP seems to reside) for 3 out of 12 months in a year. So, you believe that in 1 year the amount of decay would somehow be multiplied exponentially with the addition of fiberglass? I would welcome any evidence, supported by chemical molecular data, that this would be the outcome.
Third, "The fact that you go out of your way to say it's a temporary fix and not to take passengers indicates you already know you're giving terrible advice that will compromise the integrity and safety of the car", would suggest that I am purposely trying to put the OP in harm's way by offering my advice. I would never, ever, make any recommendation that would put another person in danger. Life is precious and fleeting. And, are you seriously taking the stance that some fiberglass in a 3'x3' space would have a disastrous effect on the structural integrity of a 3500lb automobile? Not taking passengers was a bit of a joke that maybe someone might put their foot through the floor. My bad for not spelling that out.
Fourth, "If you find yourself seriously considering repairing metal with fiberglass, it means you're in over your head and do not have the skills to make the needed repairs. Walk away and take it to someone that can do it right before you screw it up worse", that can go 2 ways. If directed to the OP, way to shame someone who might not have the finances to take their car to an $80-$100/hour shop. If directed to me, I'm certainly not going to elaborate on my skill set to prove my "worthiness" to the likes of you. My build is proof enough.
Fifth, "In a very short period of time you'll have to do it all again, and if you didn't have the money to fix it right the first time how are you going to have the money to do it twice", where do I even start with this? Who are you? Honestly, who are you to dictate to the OP that if he "doesn't have the money" to do it YOUR way the first time, then don't bother???? If you are such a high roller-big shot-restoration God then put your money where your mouth is. YOU buy the floor pan and have it shipped to the OP's address. Hell, I'll split it with you. OP says the new pan is $500. You do $250, I'll do $250. That way you can sleep easy at night knowing that there is a car driving around out there that hasn't been hacked up by some amateur, and will still "maintain the structural capabilities of the unibody chassis" as you seem to be so worried about.
The OP made no reference to having any welding equipment, or abilities, in his post. He clearly stated that he needed a solution other than "just buy them". So, I offered up a TEMPORARY solution, followed up by a permanent repair when financially allowable. It's up to the OP to take whatever advice he feels is best and discard the rest.
I am in full agreement that the BEST possible solution is to replace the floor pan with new metal.
Fiberglass is an acceptable material to use on properly prepared steel. Properly prepared is the key word. Fiberglass is polyester resin, same thing used in body filler and gorilla hair. Its not good to use in areas that flex because it can crack or chip. Seam sealer would be a better choice in those areas. Get rid of all the rust you can and rough it up with some 40 grit to give the resin something to bite to.
You have to do the best job you can do that your budget allows. A full panel will give you the cleanest results with less labor in the end. However, you can do an acceptable job patching if you take your time and blend everything in. It all boils down to time vs money. Good luck with your repair. I will take a look in my parts and see if I have any patch panels I can donate. I dont think I do but I will check my stash and see. Most of the cars I have parted were rusted beyond recognition so not many body panels on hand.
Hmm I have a scrap hood from an 01 ram. That may be an optionLOL using fiberglass is utterly ridiculous...
your welding and cutting skills will be fine for the just putting some metal in there..
With the $250 I say give 200 to the machine shop and like someone said buy a hood out of the Pick-n-Pull for $50 or less and use the material to make floor pans. Make it strong and cover it with carpet... My-2
Fiberglass LOL.......
I actually enjoy pounding and shaping metal.. If you think about it the whole entire car is overlapped everywhere and spot-welded. Nothing is cut out perfect and welded in... when I did the floorboards on my son's Power Wagon that's how I did it. I cut out a perfect patch and welded it perfectly all the way around. In the end it was a massive waste of time and I don't think it was any stronger.. this last truck I did the floorboards I put the patches in and drew a line around where they go in. Then I came back to in and cut out so I had a 2in overlap everywhere and spot-welded every inch or so. Of course one here and then one over there not doing it all in a row and warping the metal. Then I just use some car type sealer like the factory does and it was just as nice once it was painted over as the ones I did for my son's Power Wagon...Hmm I have a scrap hood from an 01 ram. That may be an option
If you think I'm the "mopar police" or some "high rolling restoration God" you've obviously never seen my cars, because they make most purists cry. Every single one of your rebuttals is 100% bullshit- yes, will make it worse, and yes, it is UNSAFE. You don't know me, you don't know my background or my finances. My advice is based on being in the same exact position as the OP in the past. And it's based on dealing with repairs made by mouth-breathing dipshits that had no business even trying and who did more damage than was originally there. And finally, its based on having a damn degree in engineering, so you better believe I know about structural integrity and how fiberglass to replace a structural floor member is just stupid. My Challenger looks like a patchwork quilt of repair panels, many of which I made myself and others where I bought only partial sections. Having done all of that, if I had to do it again, I would save longer and buy full panels for about 90% of those repairs.
Fiberglass is a bullshit "repair". Period. It has nothing to do with money, because you can make a perfectly sound temporary repair with 18g sheet metal and sheet metal screws. Throw your sheet metal screws in every 3-4" around the edge, do the same anywhere you pass over a subframe or stiffener, and you'll have a repair that is similar in strength to a properly spot welded replacement pan. Seam seal it on the edges and it will last for years. You don't need a welder for that, and it will probably cost less than a fiberglass repair. Not only that, if you do it right it will keep water out and prevent further rust in the meantime.
Throwing money at cheap, incorrect repairs will always bite you. Every time. I've done it and I regret every time I did. You waste money in the short term to spend more money in the long term because you're screwing it up. If money is tight, be smart with it. Don't waste money on temporary repairs that will make the situation worse. That doesn't mean you can't do anything, it means don't be stupid. I don't care how many people have used fiberglass in the past to repair a floor board, it was stupid every single time it was done on anything other than a fiberglass body. If everyone jumped off a bridge does that make it smart? Sure doesn't.
18g metal, sheet metal screws every 3-4" around the edge and anywhere there's a structural member. You can do all the forming with a 2x4 and a dead blow hammer and make a repair that will last for years with a little seam sealer. It won't be pretty, but it will be 100% functional. No welder, no fancy tools, very little required skill and just as cheap. And when you've saved up you can just unscrew the sheet metal screws and install the proper panel. Easy.
You're talking about bodywork bud. Floorpans on a unibody are structural. Fiberglass is not acceptable. Ever.
