I'll start by saying I understand that valve clearance has many variables tied up in the camshaft profile, camshaft advance, gasket, pistons, etc. and that the only way to know for sure is to measure when mocking up the engine. I will check clearance with a dial indicator when the time comes, but I'm in the planning stage and am hoping to get an idea from anyone who has experience running larger camshafts with flat top pistons.
My concern is that if I buy flat tops and end up needing to cut the reliefs deeper, I will need domed pistons to make up for the lost cc's from the deeper reliefs to stay at the desired dynamic compression. With the way timing goes at my machinist's, I'd likely be outside of the return window for the flat top pistons by the time I buy them, give them to him for his bore/hone work, and he gives me the bored/honed block for mock-up before zero-decking it and balancing the rotating assembly. Then I'm in a situation where I would have to eat the flat tops, buy domed, and now the engine is honed to the flat tops whereas the domed might need a different hone setup.
Here are my current build plans:
-360 0.030" over
-Zero-decked
-Trick Flow heads with 2.02"/1.57" valves and 1.5:1 Harland Sharp rocker arms
-Head gasket of 0.050" is ideal for the desired dynamic compression with the the Trick Flow chambers and cam profile
-The mechanical roller cam I am looking to use is 0.640" valve lift, 283/289 advertised duration, LSA 106, intake centerline 102
-The pistons I'm looking at are forged RaceTec 1000549 flat tops with two valve reliefs. I spoke to RaceTec providing them with the build specs and asking for their input on clearance hoping they had modeling software, and the only thing they told me was that the reliefs are 0.250" deep.
Does anyone have experience with valve clearance using flat top pistons with a similar combination? What's the biggest mechanical roller profile you've been able to pull off with flat tops?
-360 0.030" over
-Zero-decked
