62-66 A body tubular lower radiator support
Made from 1 3/4" .095" DOM and will help stiffen the front of your car considerably. It is designed to replace the flimsy factory piece and comes with all of the mounting brackets in the picture. This support can also be mounted behind your factory lower radiator support if you would like. PM me for more info. Welding required to install.
Badart
More from Badart
