j par
Well-hung Member
Again I have the same question...IMO, The only real obstacle to the 11’s with 318wills proposal is the gears.
It wouldn’t be hard at all to run 11’s with an a body using a stock stroke 360...... if the cam/converter/gear choices are wide open.
The real challenge as I see it is, coming up with a budget friendly combo that will run the number with 3.55’s.
Would you take a used stock bottom end 360 and put thousands of dollars of heads cam converters and gears and drive it back and forth to the track expecting it to do elevens for any amount of time? I'm fully confident it might do it once or twice but for season after season? Reliably being able to drive it afterwards and before?...
