Stan, What length & diameter shaft do you need? I have several old ones & I'll give one to you if I have one that is close.
Bill S,
Bill S,
They should have told you that was the way they were going to do it. If you're not happy with it they should fix it. I agree it should go the other way.So I called the drive shaft shop and they told me that is the way they build them. They said it puts less stress on the transmission output shaft. Also said fords use the slip shaft on the rear end. So I just wish they had told me that was how they were going to put it together, I might have had them do it the other way. Oh well, if it works, they said it does, then I am good with it. And it doesn't hold me up another week on the driveshaft.
I sorted all my chrome out and the only piece that needs work is the drivers front fender. I took it to a guy to straiten and remove several dings. If it doesn’t come out good I’ll let you know. Looking forward to the warmth of Florida in another 9 days. I’ll let you know when I arrive.Thanks Wayne. I have that side trim you asked about and door trim also. You still want the fender stuff, both sides?
