Rear Main?
Pan Gasket ??
Good old slant 6 oil send unit ??????
Pan Gasket ??
I boogered up the pan gasket when I swapped on the early A pan. I cannot STAND oil leaks. Surprisingly, it has none anywhere else. I'm gonna inspect the bearings like I said and I will replace them more than likely.Rear Main?
Pan Gasket ??
I do! It comes out and goes back in slick as owl ****!Rusty do you leave the motor mounts attached to the engine when pulling and installing? I have tried several different combinations. The most recent was on the 83 D150. I left the motor mounts off completely and the engine slid in pretty nice. This is with an a833 transmission. I had the bell housing with clutch arm bolted to the transmission. Was about the easiest I ever accomplished on the slant in that truck. I then went back and put the motor mounts on from the bottom.
I can tell ya for a fact, owl chit is slick. Slicker than greased car chit too. RRR knows most of is chit!Caint says I never come acrost no owl ****, but if RRR says Its slick then by golly its slick.
As promised, part 1 of the flywheel ring gear how to.
And here's part 2. Thanks for watchin.
Yeah that's the whole point of this entire project. Keep her runnin and drivin. lolSweet, Sweet, Sweet
Quick turn around on the repair.
Back to Drivin' Again !
