mygasser
that colour will look even better once the car gets all the chrome refitted. nice one
neil.
neil.
Have you checked the freezerI remember putting them somewhere were I would not lose them
Super easy. You hook them on the top and roll them down. They snap. The two small cover pieces do the same with a little more effort. I used a rubber mallet with an easy tap to make sure they were set.Looking great! How hard was it to pop those gutter trim pieces on?
In the photo post 264, the lower horn seems at a odd angle.I believe that is a perfect match
When I was scouring the local wrecking yard for horns for Dart #2 I discovered several different mounts and a couple different manufacturers. So it is entirely posable that in 68 they were different than in 67The car had every original clamp and bolts inside and out. I am sure we will find out
I updated post #264. My car was an AC car and the horns are mounted on the radiator support and the inter fender.When I was scouring the local wrecking yard for horns for Dart #2 I discovered several different mounts and a couple different manufacturers. So it is entirely posable that in 68 they were different than in 67
