Reworked/shortened driveshaft will be ready tomorrow. The goal for the weekend is to test fire the jy 360 and see what we're working with.
Dang man your really on a roll now that thing is just falling together perfectly!! I havent got Jack done!!
As good as you are when your done with yours you can come on up to va and help with mine! Haha. Seriously tho man that thing is coming together perfectly! This has become my favorite build on fabo!
Yes Merritt island. It's a beautiful place.He's on Merritt Island I think you said? Wouldn't be that hard. If you got kids that's different. And yes, summer does SUCK. But it's better than sleety, rainy, snowy winters.
Any 2nd attempt after the timing issue was solved? I dont know how you slept a wink without getting it to start lol.Got everything hooked up yesterday for test fire. Late in the afternoon gave it a try. Nothing, nada. Turns over but not one single pop spit sputter. Did some checks, everything looks o.k. I think. Had me scratchin my *** a little. Then I was laying in bed thinking about it and it dawned on me. Before I put the distributor in I torqued the harmonic balancer bolt. Spun around a little. Tried to back it up and the timing gear backed up and out. So I ran it all the way around back to TDC. Timing gear back down, all good, pointed at no 1. Then dropped the distributor in. Rotor on number 1. Duh.
Yep had a few minutes this evening. Distributor was 180 out and finally got a little noise out of her. AND a backfire. Then nothing. Hmmmmmm.Any 2nd attempt after the timing issue was solved? I dont know how you slept a wink without getting it to start lol.
Did you check to see if you are getting spark at the plugs?Yep had a few minutes this evening. Distributor was 180 out and finally got a little noise out of her. AND a backfire. Then nothing. Hmmmmmm.
Back to the drawing board. I'm confident with the coil, ECU, distributor, ballast and harness. I did however through on a rotor, cap and wires I wasn't sure about. Sure as **** took it all apart and found a badly corroded in the cap coil wire (that's embarrassing). How did that happen? I was excited. Doesn't matter, should have checked them. One bad plug wire, too. Back to O'Reilly's. Try again tomorrow.
No, never ran. Fuel is good to go. Pumps good. Carbs good.Did you check to see if you are getting spark at the plugs?
While you have them pulled check and aee if you are getting fuel.
Did it run before the backfire? If so how long?
Cool deal. Yea that sounds like it would be a problem.No, never ran. Fuel is good to go. Pumps good. Carbs good.
The coil wire and cap is trash, no way was it getting good consistent spark at the plugs Trust me there, lol. Used **** I had hanging around the shop. Looked good, but pulled the coil wire out and the end crumbled. Oops.
If you saw it, you would wonder what the hell was I thinking. Gonna start with new ignition parts before I start troubleshooting, if it's nessasary. I fully expect it to run. Thanks, though.
I'll update tomorrow.
Look closer, lol.I went back and looked and found the pic that you posted. I can't see the dots ?
Oh no not this again!! HahaYou have the dots wrong. The dot on the cam gear should be at the 6 o'clock position NOT 12 o'clock. Crank gear is right.
If your timing for cyl 6 compression, yes. My qustion was about cyl 1 TDC.
