2 days later... I’m finally caught up on all this rigamarow.
Rigmarole?! I resemble that remark!2 days later... I’m finally caught up on all this rigamarow.
.A few shots of the dumpster fire 318's 675 heads. Valve guide eliminated for .5" bronze, and cut for 1.94 intake valve .
I think he is flowing them after working them, shooting for 210 cfm with high velocity is what he said..
Have you or are you going to flow bench them?
They look pretty but do they flow good?
Where? Do you say that?I think he is flowing them after working them, shooting for 210 cfm with high velocity is what he said.
skrews started a thread asking if anyone had flowed stock 675's. he stated his goalWhere? Do you say that?
AGREED!?? HEY!!!!Rigmarole?! I resemble that remark!
Of course but it wasn't appropriate timing...
How much will the transfer case take in my '85 Ramcharger? What if I built a 450 hp 440 with 500 ft lbs of torque, raced it in 4 hi ??? I think the '85 has a NP208 aluminum case.....An interesting site I found today.
Dodge Mopar Plymouth Reproduction Parts - Cuda Challenger Charger Road Runner Duster Demon - Musclecarparts.cc
Don't you have a whopping motor in one of these older units?I can say that I only broke one 203 transfer case, it was in a 340 powered jeep cj-7.
But I did snap the cast iron housing between the trans and transfer case one time in my 77 Ramcharger, 44" tires are somewhat hard on stuff.
.How much will the transfer case take in my '85 Ramcharger? What if I built a 450 hp 440 with 500 ft lbs of torque, raced it in 4 hi ??? I think the '85 has a NP208 aluminum case.....
I guess the winter is getting to me...
yes, I believe aluminum NP208. Snap like a twig??? LOL... Didn't they go aluminum and never look back? Aren't the transfer cases behind the V10's and even Diesels aluminum?? Asking, because I'm not a 4x4 specialist..
I think the 85 has an aluminum snap like a twig transfer. The 77 would have a 203 which was used behind about everything from a slant 6 to a 440.
41 and rising.
.yes, I believe aluminum NP208. Snap like a twig??? LOL... Didn't they go aluminum and never look back? Aren't the transfer cases behind the V10's and even Diesels aluminum?? Asking, because I'm not a 4x4 specialist.
And the NP203 has the chain drive? Isn't that the weak link? I thought the NP208 was gear driven? Again, asking.... because I'm too lazy to do a google search... LOL
Maybe mines a 205 in the '85?.
Personally I like the new process 205. Gear Drive, divorced, tough unit.
.Maybe mines a 205 in the '85?
I know my 77 is a NP203
I have no idea. I've mostly stayed away from 4x4's..
No you don't have a 205.
Don't v10 & diesels use a 241?
Yup. V10s and diesels use two different versions of the 241..
