I think he's just joking. I didn't see any magic taking it apart and it looks like putting it back together will mostly be a matter of keeping the bearings in place. And using the correct grease !!! LOLWhy would you want to keep it secret but tell people about it? The reason for a forum like this is to help other people. If you don't want to share your method that's fine but don't be childish like that.
easier method !!???go back to post #161, ok other guy commented he had secrets, jpar said he likes secrets,
was in jest, get a life!! Actually there is an easier method.
All the gears and the shafts and stuff go into the big cast iron piece with the big hole in the side...
I share what I have learned, cuz it's the right thing to do. Can you imagine a world, where the first man, Adam, never shared what he had learned, and every generation after him had to learn it on their own? There might not even be a world, if he hadna learned how to procreate!
Great thread, in large part due to your contributions. The OP is doing a good job here as well. I'm learning from it so thanks. I totally get the 4 speed fun factor. Planning to try out an OD unit. Might blow it up but so be it.:burnout::burnout:
I'm pretty sure when you take the overdrive transmission apart you have to drop the cluster gear in the case to get the main shaft of gears out.
Thanks for the kind words. and please keep in mind that the O/D gear in that box is extremely weak. I am not kidding. If you have a V8,be nice to it or be prepared to walk. When it blows you have no idea what kind of damage it will do inside there! For a while I was buying boxes at swap-meets, for spares. It's really easy to forget when you are used to banging gears, with 3.91s or better! Keep you walking shoes in the trunk....
ATTENTION !! -- I'm almost positive that you have to drop the cluster gear in the case to install an OVERDRIVE 4 speed and then pull it up into place after the main shaft is installed. I'm sure its because the overdrive gear (now occupying third gears spot) is to big to clear the cluster.
Yes I did kind of spot glue the gasket on the case. I'm not absolutely positive (mostly because I don't have one) but everything I've heard is you can't set the counter shaft before the main shaft in an overdrive. As I recall correctly thats what I was told when I called brewers Proformance.No other way to do it, the mainshaft gears won't clear the cluster gears with the counter shaft in place.
Also one tip I've learned is to glue the tail shaft gasket to the tailshaft, one less thing to worry about when trying to load the main shaft into the housing and keeps you from tearing it.
Ok, here's what made the (hard part) so easy - unlike the picture I'm going to show I have the tail housing upside down and and less than one minute of help from my nabor to catch the input shaft as it came through and maintain a little bit of back pressure so the input shaft/4th gear held on the main cluster and didn't spill it's contents. My nabor did hang out with me for a few and actually provided the correct size piece pipe to slip over the input shaft to tap on the main front bearing.
notice the upward angel ? Important ......
those are not my furry arms, I copied the picture from the tranny rebuild book (recommend) highly !View attachment 1714851713
j par, haven't read every reply so this may have been brought up before. Mark Williams makes billet caps for the 8-3/4. Needs some surfacing to fit and may not fit all housings.The caps you had were the best ones from the factory. Wonder how long the others would have lasted? Bob
And if you don't fix the clutch, you'll be busting up the D60. You can keep throwing parts at it, but the clutch will kill it. I know. I was doing it before you were born.Yes I seen the Mark Williams caps for $105 plus I have to take them like you said to have them worked over or something. by that time I would start thinking about just getting a nodular case from dr. Dif for $300 with billet caps. Then by the time I had to buy new gears new bearings new axles new spool and all the other stuff. I decided to just go with the Dana 60 have already bought a Dana 60 with 410 gears that I can use for $160. You can see my thread on the racers part of the forum called " budget Dana 60".
