Matts440
Most BOV’s leak under idle vacuum. Loosen them back up, and if they close when you blip the throttle you’re good to go. Only tighten to overcome higher boost.
They do, I was always under the impression if they leaked at anytime they were bad. Good to know, learning all the time. Thank you.
