Agreed. Id 1050x injectors on the way.A good set of matched injectors, a re scale, and a re tune with both pumps on and you’ll be stylin.
Maybe
Yea you’re only like 12 degrees short on timing. No wonder it felt soft.These runs were 65% ethanol
Static pressure at 60psi so injectors scaled at 1250cc
This brought up another thought. Reading back through Subcom’s threads he’s running more timing advance (at least out of boost) than I am. 40 degrees max at 10.5:1 compression. Mine is set to 36 at 9:1. Any suggestions on how to determine where mine should be? It wants 20 degrees at idle.Yea you’re only like 12 degrees short on timing. No wonder it felt soft.
I did look at that wrong. Just 40 in the region you won’t spend any time in.Mine is about 32 total before boost. Then up to 7.5psi I'm pulling about .5 degree for every 1psi and then about 1degree for every 1psi of boost after. I did bump it up to 21degrees at 14.50psi in the upper rpms last time but typically it would be about 18degrees. View attachment 1716317721
I see your A/F ratio is low 11's... with this type of fuel, is it still a little rich? When I had my Omni, I looked for 11.8 w/ race gas. I'm Just curiousThese runs were 65% ethanol
Max N/A power advance? Or max cruise, no load advance? In cruise, no load/light load you can be up around 50 degrees for fuel mileage. Power timing is dictated by how efficient the chamber is. Remind me what cylinder head you are using and what kind of chamber it has. You’re probably not too far off at 36.This brought up another thought. Reading back through Subcom’s threads he’s running more timing advance (at least out of boost) than I am. 40 degrees max at 10.5:1 compression. Mine is set to 36 at 9:1. Any suggestions on how to determine where mine should be? It wants 20 degrees at idle.
It is a little rich, but more interested in staying safe. From what I’ve seen the non intercooler guys aim for around 11.2:1 and the intercooler setups run a little leaner.I see your A/F ratio is low 11's... with this type of fuel, is it still a little rich? When I had my Omni, I looked for 11.8 w/ race gas. I'm Just curious
I have the cnc speed masters with 65cc chambers. Probably not very efficient. I’m mostly interested in the max N/A number as a starting point when it comes to pulling timing for boost. I’m assuming I would need to make some N/A pulls and check straps to get an accurate number?Max N/A power advance? Or max cruise, no load advance? In cruise, no load/light load you can be up around 50 degrees for fuel mileage. Power timing is dictated by how efficient the chamber is. Remind me what cylinder head you are using and what kind of chamber it has. You’re probably not too far off at 36.
That’s a pretty common cylinder head around here. You could probably poll the audience and come up with a good number. It’s a cnc closed chamber with a decent spark plug location. I’d bet that chamber wants 33-35 degrees max power timing NA.I have the cnc speed masters with 65cc chambers. Probably not very efficient. I’m mostly interested in the max N/A number as a starting point when it comes to pulling timing for boost. I’m assuming I would need to make some N/A pulls and check straps to get an accurate number?
Shoot me your log and I’ll look at it in megalog viewer. Hard to see from your screen picture. When my old converter was slipping it was like driving a golf cart. You couldn’t feel the gear changes and the RPM was stuck at like 6200-6300.Started a thread in the transmission area. I feel like I’m down on power and wondering if I’m blowing through the converter. Pretty certain I should buy a certain PTC converter for sale on here. Spoke with John cope and he said my logs look like I opened a parachute after shifting into 3rd.
This is essentially showing 2.85 seconds from 100-150mph if there was nothing slipping between the crank and tires. My car isn’t that fast.
Thank you. SentShoot me your log and I’ll look at it in megalog viewer. Hard to see from your screen picture. When my old converter was slipping it was like driving a golf cart. You couldn’t feel the gear changes and the RPM was stuck at like 6200-6300.
