I've seen worse welds. Those aren't that bad. Practice makes perfectMade a sturdy bracket out of 1/4” plate today. My welds are crude but my v-bands and everything lined up perfectly.
It’s so tempting and would be sooo much easier!Looks fantastic.
I vote for the wastegate dump going straight up through the hood. Do it!
Boring but quiet and I’m the same same way. I “want” the wastegastes spitting fire out the hood. But I almost always plumb them back to the exhaust.It’s so tempting and would be sooo much easier!
I tried to mock something up that would go down and snake its way past the k frame and towards the rear but just too much crap in the way. I just got some stainless 2”. I’m going to merge it into the downpipe. I know, boring.
Good eye! I do have a 2nd one coming from the front of the oil pan. If that’s not enough I’ll connect the other valve cover.In Post #409 you show 3/4 PCV ports plugged. In Post #417 you still show 3/4 of them plugged. Under boost you are going to generate massive amounts of blow-by. I would at least have a crank vent on each bank. The provisions are already there.
lol. I do this realizing already that after about 1 mile behind the wheel I’ll want to rip it all out and start over with a muffler and an exhaust dump. Why do it right the first time when you can do it 2 or 3 times?My downpipe ends at around the same spot. I’ll pray for your ears lol
