dirty white boy
50 yr old Juvenal delinquent
question? would you wanta restrict oil to a factory hydrolic roller lifters???
.question? would you wanta restrict oil to a factory hydrolic roller lifters???
Back earlier in the thread guitar Jones showed the method to use if you were using hydraulic lifters..
No only solid lifters.
Photos seem to be there for me. The photos do not start till quite a few pages in. I just looked at the thread again and I get pics.Is there anyone who has all the missing photos from this thread?
Cley
What post number are you talking about?Is there anyone who has all the missing photos from this thread?
Cley
.28, 73, 107, 124, 126.
it's the meat and potatos of what I hoped to learn and the photos don't show up for me. Maybe it's just the computer I'm on. Does everyone else see them?
Cley
.Question, if the right lifter galley is tubed & #1 main is blocked off, how does #1 main get oil?
I had a used 414 engine that had been tubed & running solid roller lifters.
It didn't have a crossover tube in it.
If the passenger side is tubed you do not use a cross over tube. The 1 main is oiled normally and the passage is blocked on the drivers side.[/QUOTE
Thanks
Sounds good.
So tube option is a good idea for high reving flat tappet applications as well ??Sounds good
I saw the tube kits offered on Fleabay !
.So tube option is a good idea for high reving flat tappet applications as well ??
If so I will purchase one because block work will begin soon with my build.
.Here is a video showing the plug that is below the main cap.
Also the Chinese oil pump production QC failures unless I’m missing something and someone can explain it better.
View attachment 1715240774 .
First question is did you remove the plug that you show at the first of the video that is up under the main cap. If not you need to because there is a bottleneck under there. It needs to be drilled out.
Now on the pressure relief valve in the Chinese oil pump that is not a problem with that hole being exposed because that is just part of the valve that bleeds the oil pressure back it is not what actually stops the oil flow at low pressure. You will find when you pull that out that the valve has other orifices on it and at the head inside where the spring sets is solid.
I believe you need to pull that valve anyway to clean up the passage behind it.
I think that you're over thinking that relief valve is what I'm trying to tell you and that your new Chinese pump is just fine..
Also if you're going to use the crossover to feed the number one main you didn't need to drill out the passage coming down from the passenger side to the main. That being said if you do use the crossover you do not need to drill that passage out bigger anyway because it is only one rod being fed from that journal.
Enjoy your two videos. Especially the little ball of energy that was running around there.
Which galley needs to be plugged coming from #1,
Why?
And do I really need to have the crossover if the galley to mains are opened up on all journals and full flow is capable to entire block?
How do I mod the pickup/plate from bottom of pump cover to suck properly?
Questions in video below.
Nice video I see you have your star in it. Look at this thread I just created and see if it helps you out.
Are you going with a solid or a hydraulic cam?
Are you going with a rear sump pan?
If so you know you cannot run a pickup off the bottom of the pump. You need a rear sump pan to do that.
Still working on getting my pictures to upload on my thread I started.
My take on the oiling system crossover tube for the small block
