Straight from a street racer...
I already have the SS springs, so I'm hoping to keep using them. If I have to change things to Caltracs I will. I'll even 4 link it if I have. I'll only do that if I can't get what I have to do the job.
I know Chuck Lofgren, that's where I did my motor about 4 years ago. I do have weld in subframe connectors but they don't pass through the floor. I need to step up to the better frame connectors that go through the floor and a 8 point rollbar to stiffen up the body.
You don't necessarily have to have frame connectors going through the floor. Tieing the 8 pt. roll bar into them with the angled bars off the main hoop, behind the seats, will help a lot. If the connectors touch the floor anywhere, they could be tack-welded there as well.
A 2.71 low gear 904 may be too much for the stroker and small tires and make it harder to hook! But do get the tallest tire you can and install on the widest rim that will fit (i.e: 9" tire on 9"-10" wheels.). A taller tire actually puts a little more "footprint" on the track. But you may have to make up for the height with more gear.
I'm not surprised that 15 year old tires spin downtrack. I'd consider that a safety issue.
Make sure your drivetrain is up to handling the "hook" when you get there. Hopefully you have a driveshaft loop. But I like to use Spicer solid u-joints and a billet steel rear end yoke because OEM versions can eventually start to spread when abused.
Sometimes to get some consistency, one has to break down and add weight in the trunk.
Consistency wins bracket races and gives you more time and money to figure how to go faster.
I've run 11.50's at 112-113 mph with 1.50 60' times. That shows that you have some tuning and matching of parts to work on to get the combo more efficient. (Carb tune, converter, gears, shift points, etc.) Just getting it to quit spinning down-track should help mph. But you seem to have a good base and on the right track with a lot of good advice in these threads.
What are your 60' times now. 500hp should be closer to 125mph in the quarter. You either had a very friendly dyno or you have some serious issues somewhere.
Thats got to be a heavy dart. As far as "can it hook", my duster has gone 1.67 on a
6.9" wide Polyglass tire. You can get any combination to work if you put the effort in.
79410aspenrt, do you know a Mark Turner from Verndale, MN?
dont spend the money on calcrap look at some old school pics wheels up in the air with ss springs google it wheelstanding mopars. a buddy of mine did the caltracs on a 72 dart 408 stroker did nothing to change his times but i got some nice parts. buy some good tires/rims 15"
.. Mine seem to work pretty well and both of my cars do not sit like a 4wd..SS springs are outdated and mainly for those who either choose not to learn how to tune a suspension or just can't. Or for those just having fun and really do not care what the car runs...
Just my opinion....
The front end is more important than what's under the back end...
