OldmanRick
You won't get there with that MPH.
6400, 27" and 3.91's = ~15.5% converter slip. That's your biggest issue. Slip number is REALLY bad if the tach is correct. The converter is not a good match.
Post all incrementals from your best run. Someone will find something
You have a nice car and it's running decent in my opinion. But you have some top end slip for sure, at least 500 rpm's more then being efficient. But even so, if your looking to get into the 10's, i'm not sure i'd look at another converter just yet. I think you'll need to make some significant power upgrades to get there, and that will require a spec'd converter for that combo. I'd just hate to see anyone dumping $$$ into these things along the way just to replace them with another upgrade. I think your 75hp or so away from your ultimate goal.
Just my opinion. :thumleft:
Good Luck moving forward.
