lead69
hopeless car junkie
I have only checked high performance t-stats but the multiple ones I tested started opening lower than the advertised rating (10 degrees or so) and were basically full open by the time they reached temp.
Yup, that's my experience as well. I always chuckle on these threads where we are clearly discussing high performance applications and everyone wants to throw stock crap parts in the mix, just so they can be "right" while not realizing that makes them even more wrong.I have only checked high performance t-stats but the multiple ones I tested started opening lower than the advertised rating (10 degrees or so) and were basically full open by the time they reached temp.
Don’t be a literalist. Packing up, backing up, obstructing, impeding, blocking, restricting, whatever you wanna call it. I posted what I experienced with this Derale:
View attachment 1716086405It wasn’t cheap $$ that’s for sure. Flat plate shroud with high CFM fan. It didn’t take long for me to discover it had to go. You may have known this from the beginning of time, at the time I bought it I had to find an 18 inch fan with shroud that would fit my situation for dragracing and street use. For that it was fine, although I had to run it more than I care to. It was no good for Highway use in my application. And that style is what I am referring to which is the exact same thing you are referring to.
As to your assertion that I said a mechanical fan was “necessary“ maybe you have misread or perhaps you misinterpreted I don’t know, this is exactly what I stated:
Re-reading what I typed, it could be you are focusing on the part: “and/or” and perhaps I left out “or” between “blocking airflow, OR a good mechanical......” Was not implying having to use both, no sir. Perhaps I was not as specific and clear as I could have been. Grammatical errors happen.
Instead of seemingly looking to pounce and parse maybe try asking for clarity or simply give the benefit of doubt. No big deal. I know I need to sometimes so, anyway, have a nice evening
I said this in another post but the application can be what determines what fan does the best job.
The horsepower rating of the engine is not necessarily a good yardstick for what fan is needed. For example: You have an engine that makes 700 hp and you use that power for an occasional burst of acceleration then spend the rest of the time using 20 hp to cruise down the road or idling at a stop sign. Compare that to an engine that makes 400 horsepower that is being raced in a circle or on a road course that spends most of it's time making close to that 400 horsepower. The cooling needs of the two examples can be very different.
I think a better way to think of how much heat you need to extract is horsepower over time.
Electric fans have come a long way. They are more efficient than ever. But they move the same air if the motor is idling or at full load high rpm. Mechanical fans while not load sensitive are rpm sensitive. They move more air with increased rpm. They also have a power source that can power a large aggressive pitched fan blade. Try putting your hand in front of a radiator with an aggressive fan spinning 6000 rpm inside a good shroud. It moves alot of air.
Something to think about and I don't know the answer too. An aggressive pitched 4 blade mechanical fan can use 7 Hp. Assuming the fan efficiency was close to equal (maybe it isn't) how big would the motor on an electric fan need to be to move the same cfm that the mechanical fan is moving at 6000 rpm?
wrong!! go do some research on cooling a dirt track car and you'll learn a thing or two!! go to a dirt track and walk around pits and ask some car owners if you doubt me!! electric fans been tried from high dollar aftermarket to ford 2 speed tarus/mini van fans and no body has yet to get them to work good nuff to run less the ambient temps are 65 degrees or cooler!! dirt racers would love to get red of there mechanical fans cause at race speeds that 30 hp thay could use else wheres, specially in the crate class's where each car got same exact 400 hp engine, thay'd pimp there mom out for a 20 hp advantage!! you can bet on that by god!! brought up cooling a dirt track car cause it takes a good system to get the job done! enjoy reading most of your post as thay are on point with good info, but im right on this, been there and done it, know it, spent good money to learn it!! got 4 crate model's setting here now!
I have done the research on cavitation. And not just with automotive people. Cavitation is very rare unless the inlet side of the pump is restricted. Unless the hose is collapsing or some other issue is restricting flow to the pump the number of blades isn’t an issue. You’d have to show me real world examples of cavitation in automotive water pumps that were caused by too many blades.
180 degrees is the HOTTEST any of these engines should run and that’s not “left over” from my drag racing days. You are hung up on your number because you are stuck in your new car, hot coolant days. The “modern“ engine is nothing close to what we are discussing here. No one is using knock sensors and **** like that to pull timing on the stuff we are talking about.
Making power is about cylinder pressure. Cylinder pressure makes heat. Heat is power. Heat also promotes detonation. New (or “modern” like that means better…it doesn’t) engines deal with detonation by using knock sensors. They are also concerned with cold start emissions (I’m not), getting the cats lit (again, not a problem we are discussing here) and certain emissions levels (again, not relevant in THIS discussion) so trying to marry “modern” engine operation conditions to what most of what we discuss here is LUNACY.
But, here is the real clincher. Wait…I need to mention I haven’t done any work (as far as tuning and such) on any “modern” engine newer than about 2003 so keep that in mind…the real clincher is dropping the coolant temperature even on those engines increases power.
Now take off the EFI and all the related **** and drop a carb on one of those and run the coolant temperature up and see how fast detonation drops the power. It will start killing 20 HP so fast your hear will spin. And you have to add fuel and reduce timing (which makes more heat in the exhaust) which makes less power.
So get out of your head that coolant temperatures of 160-180 are a “drag racing” thing. Most drag cars have undersized, piss poor designed cooling systems that don’t control engine temperature like they should. That’s the big reason why drag racers (and corner turners) gain power when they switch to alcohol. They need the heat to vaporize the 2.2-2.5 times more alcohol than gasoline. Had they spent the money and time to unscrew their cooling system they would likely see little, if any gain from alcohol. And when that happens they see very little savings in fuel costs since it takes over twice the alcohol to make the same power as gasoline.
When I was tuning circle track engines (another group of people brainwashed that hot engines make more power) the FIRST thing I did after unscrewing their tune up was to make them buy a better radiator, a better pump and made them either sell or scrap their under drive pulleys. It was a fight for the first couple of people.
Once I was done, those guys finished 1 and 2 in points and neither one ran over 170 degrees. And all the long time smart circle track guys told them the engines would be junk when I did the freshen up at the end of the year. Of course, those morons were wrong.
I made them come to the shop on the weekends and they took their own junk apart. Then they watched me measure everything. We could have reused every part.
I have debunked the cool(er) engine temperature kills engines lie so many times its just stupid that it keeps coming up.
Again, these customers were running mostly on 3/8 dirt but they eventually went to 1/2 mile pavement. So the aero stuff doesn’t apply to them like it would to a car capable of more MPH, which is EXACTLY why cars at that level keep the coolant temperature as high as they do. I already talked about that somewhere else.
There is zero downside to running a cold(er) engine. I’d run mine cooler but at temperatures lower than 160 I can’t get defrost to keep the windshield clear.
Once again, you're looking at this whole thing through the VERY narrow window of maximum power output on a dyno or at the drag strip. All of your examples are drag racing or dyno's, and it's why you're so dead set on this (and wrong for other applications).
I know you're well versed enough in building engines to know that max power output is not the only way you can tune. It would be very different from a maximum efficiency tune, for example. And you throw out "drivability" too, and for street drivability there will be very few engine builds where tuning for maximum power will actually give you the best drivability. Tuning for mid range torque, for example, vs maximum hp, would give you a much more street drivable car. And that's not gonna push the limits of detonation. For that matter, a lot of engines in these cars are no where near pushing the limits of detonation.
As I said before, drag racing is quite possibly the ONLY automotive motorsport that runs coolant temperatures below 180° or colder. There are much more exotic engines that don't do that which go A LOT more miles than any drag car or even most of the "street" cars discussed on this board.
And you can't just say this is limited to 50 year old engines, because I've seen you give this advice to guys with modern engine swaps. You're giving out advice that's good for the niche it belongs to, but is not necessarily correct for everyone that you're giving that advice to. There ARE disadvantages to running too cold. Just because you personally haven't seen it doesn't mean it's not true. You're not basing your advice on engines that are meant to go 100k+ miles. And yeah, most people don't drive these cars like that. But your advice is not absolute. It's a single way, out of MANY ways, to tune an engine.
I'm not gonna argue with you on this. I'm sure what you do works for how you build engines and how you drive. But it's simply not scientific truth that the way you do things is in fact best for all engines and all applications. For a drag car or a street/strip car, sure. For anything else, sorry, but no. Your experience in this, while valuable, is anecdotal.
......yeah and every single one of these antiquated books had ZERO clue about how ethanol laced gas would affect these engines. Leaning them out, causing hot spots and so on. You have to compensate for "whatever" fuel you run in the tune, or it'll never run right. Some of these guys just want to be right, no matter how wrong they are.how old is the info in these books yall posting? post pic of copyright dates in the front of them books!! yall ever think technology advances, or stands still threw out time??? theres cheap stock replacements stats, high priced stock replacements and then theres better than stock, think there all made the same??? not a fan of t-stats my self just something to malfunction and cost ya a head or hole engine! takes just a few minutes more to warm up but never any doubt my coolant flowing!!
I haven't seen anywhere once in any of these discussions where you've mentioned racing only. I don't know where that's coming from.But YOU are arguing. I drive my **** ON THE STREET. Just because YOU cant or won’t do something isn’t my problem.
Maybe you ought to drop your coolant temperature, retune your carb and ignition and then report back how shitty it runs. Or maybe how much better it runs. ON THE STREET.
Get the “racing” thing out of your head. That’s your mental road block.
I don’t think I’ve ever said for an EFI (junk you call “modern”) deal to drop the coolant temperature. If I have, it’s because of testing on STREET DRIVEN CARS close to two decades ago.
Your street car and my circle track car are polar opposites when it comes to cooling system requirements. But for the sake of this discussion let's say that what they have in common is that they both have motors that make 400 horsepower. That is the point I was making in the post. Different applications require different cooling systems including fans.That may not be a cheap fan cost-wise, but as you found out it's completely inadequate. The fan shroud is just a cookie sheet, not a piece that was designed for air flow. And the fan itself is only rated for half of what you'd need to cool that engine, if that.
Buying an expensive aftermarket fan does not guarantee success. You need to make sure it can put out enough CFM for your application, and it has to be designed to work with its shroud to flow air. The Ford Contour electric fan set up I run costs significantly less than that DeRale, and flows twice as much air.
Your RPM example is exactly why mechanical fans are inefficient. The fan has to do the most work at idle, when a mechanical fan is turning the slowest. At higher engine rpm's the car is MOVING, which means your airflow is coming from the speed of the car, not the fan. You don't even need the fan to be spinning at all once you're doing 25mph or more. The electric fan always spinning the same speed is an advantage, it can flow the most air when the engine is at idle and the car is sitting still, which is exactly when you need the fan to be doing the most work.
And yes, I am very familiar with how much air a mechanical fan can move. Which is why I picked an electric fan that can move just as much. If you've ever seen a Contour fan set up running at high speed, you'd know it moves just as much, if not more, than the mechanical fans these cars came with. Especially if the engine is just idling.
I don't need to do any research on cooling a dirt car, there are electric fans more than capable of cooling those engines. But as you said, the class of racing you're talking about doesn't run alternators. An electric fan that would cool those engines needs to be supplied with 40+ amps of power to deliver their rated CFM. This just goes back to the basic mistakes people make when choosing electric fans- they don't pick a fan with enough CFM, they don't wire it with the heavy duty wiring and relays needed to supply the power they need, and they don't run a power source capable of feeding the right amount of power to the fans when they're running.
I have no issues cooling my 400+ hp, all iron 340 with the electric fans I run. They never even come on when my car is moving more than 25 mph, and they've cooled it just fine when it was 110° out and I was stuck in traffic. That's a harder ask than anything a dirt car with 400 hp requires.
That book I showed is from 1970. The Mopar Performance book (when was the thermostat tech written, not sure) shows this:......yeah and every single one of these antiquated books had ZERO clue about how ethanol laced gas would affect these engines. Leaning them out, causing hot spots and so on. You have to compensate for "whatever" fuel you run in the tune, or it'll never run right. Some of these guys just want to be right, no matter how wrong they are.
That is the same style thermostat Stewart Components makes.Here’s a good post from a few months ago. I like what the poster says about his temp gauge readings:
[ATTACH=full]1716087589[/ATTACH]
NoCar340
The Original Partstitute
One more thing I rarely see mentioned: The thermostat itself. This is a factory air-cleaner decal from a '70s CB300:
It was made by Robertshaw for Chrysler. The design of the stat was so important ("WILL" rather than "MAY" CAUSE OVERHEATING) they included a drawing of what it should look like. It's no longer available new anywhere; NOS is the only option. Sounds terrible, but several other vendors sold the Robertshaw unit under their own names and part numbers (Purolator, Atlas, even CarQeest at one point) so they're still out there. Cross-references are only good if the stat looks like the diagram above.
Does it make a difference? With dramatically increased flow, it certainly should. My '69 Valiant has a 10.x:1 340 w/painted headers, a shroudless thermal 5-blade clutch fan and a cheap 22" Chinesium/aluminum radiator. The VDO mechanical gauge stays at 180° like the needle's welded in place with ambient temps above well over 90°. The factory dash gauge is similarly steady (both gauges work simultaneously) and I've verified with an IR heat gun. I can't swear it's the 'stat, but when the ambient air is 98°, the car's motionless and running, and the needle stays planted like that, I'm not trying something else.
I could be wrong but I think Robert Shaw makes the thermostat for Stewart Components. Stewart Components modifies the thermostat for racing by drilling bypass holes in it.That is the same style thermostat Stewart Components makes.
I believe that's correct.I could be wrong but I think Robert Shaw makes the thermostat for Stewart Components. Stewart Components modifies the thermostat for racing by drilling bypass holes in it.
NoCar340
Go with the 160. I mean seriously. Get the hot water in your sink up to 160....IF it'll go that high and see how long you can stick your hand under it. lolLooks awfully close to the Milodon high-flow t-stat, I have one in both my D200 and Duster along with ECP aluminum radiators and high-flow water pumps. Neither ever have cooling issues. I've towed my Duster on a U-Haul trailer with that truck to a track and back over I-25 when I was in CO, just for kicks I held the pedal to the floor going 75 mph up a 6% grade for at least 30 seconds and the water temp gauge never went over about 210 (thermostat is rated at 195).
Since moving to the Southeast I should probably swap out the 195 'stat in the Duster for a 180 I already have. I don't really have to worry about driving in 20-degree ambient temps anymore and needing a heater lol.
Man I don't want to jump in here but...
Keep in mind the only time the thermostat flows "high flow" is when it is fully open. Before that it is regulating the flow needed to maintain the low temp, on a cold day it might be bairly open.
I'm going to regret this
