Ooh also got my new fuel lines from the mech pump to carb.
Nice the original dodge emblem for your trunk. Was you car originally a dart custom? And bummer on wrong address geez that’s a lot of bullets.
jmo, they all look better without itThe trunk actually looks pretty good without the trunk trim...
Cosmichrome is the best I've seen but it sure as hell aint in a spray can. Gotta be somebody in Vegas with a Cosmichrome system. Of course ya have to pay for that. Doc seems to like the DIY approach.All "chrome" paint sucks. It is a joke. All of it, every brand. It will forever be rubbing off onto whatever touches it. Even if it actually seems "dry". Strip it and do something different.
By the way, most bedliner is not paintable.
The bigger the project the more equipment and people it takes. The piece has to stay wet. I actually have the equipment but have not used it yet. It's expensive. The topcoat is basically urethane clearcoat with a little violet tint to keep it from yellowing. The beauty of it is non metal pieces can be "chromed" and it can be tinted. The tint goes in the clear. The chrome is silver. Real silver hence the expense. The generic procedure is called gilding.Is that the system where it takes 2 guys.....spraying like hell, to get it on properly? I saw a video about spray chrome once, and was like watching those 2 guys!
One more reply about it...and I'll quit hijacking Doc's thread. I just went to You Tube and watched a guy chrome paint a crotch rocket fairing. He wasn't painting it.....he was HOSING the stuff on. More was dripping off than what looked like stuck! It turned out beautiful, and it took him 8 minutes from start to finish. I guess it must all be in the chemical reaction between coats.
I think im caught up now. Let me just say wow, you made killer progress on this thing in short order. Kudos
What are you going to do with the carbon?
Is it the real stuff, that you need to heat to harden?
Just asking, I work in a place that builds carbon-fiber aircraft parts.
Hey Doc, keep your hoverboard at home while you're pulling teeth!!
What do you not like about dentures? I Had one wisdom tooth pulled and it was hell. Now the worthless tooth above it has a cavity and I am apprehensive of having it pulled.Man this guy got 12yrs for medicine fraud... pulling teeth is easy though, I pulled 12 on Friday in about 1hr and 15mins.... then finished some dentures... i absolutely hate doing dentures haha.
Seeing that the tooth is not doing anything, ie. it has no opposing tooth, extraction would be the best alternative in the long run.There is just always problems when doing dentures. Its hard for people to adjust to not having their "natural" teeth anymore, they have to be adjusted quite often because without your natural teeth the bone is constantly remodeling. Dentures don't stay put all the time and they are uncomfortable, etc etc.
Lower wisdom teeth are rough, they are usually all the way in the bone and are harder to pull. If you can save the upper tooth and put a filling or crown on it do that. Your natural teeth are the best teeth.
