OOboy here we go!!!!!!!!!!:wack::wack::argue::argue::angry7::angry7::bs::bs::bs::bs:Hello!!!..........
I got to say it.. Its the big block that is slowing your A-body down. Everyone likes the idea of a big block in an A-body, and that It is going to be soo fast.. Reality check here.. I know this is not helping your need, and this could be covered under a whole different thread, but like I said had to say it.. A Stock 340/ good 360 with stock cam and manifolds run better than that all day long at the track.
More than likely get your timing right and Carb right, and proper traction you will pick up 3-5/10ths. Like the guys are saying. your not going to see low 12's, without a lot of changes in gear, traction, and more H.P
pay no attention to the smallblock boys, a properly built 383 will walk all over a smallblock. I think your combo is just a couple parts and tweaks away.
arguing about whether a SB would kick a BB rear helps a lot. Maybe it's the air int he tires.
Good luck with this.
As others have stated and most are ignoring, that mph is too slow. Are you sure that you are getting full throttle opening?
do you have any cylinder pressure? if so, what is it ?
Before you spend money going to a dyno, get a different carb. Carb should be #1 on your list!
If you must use that POS carb, find out what the rear metering plate is installed in it. Jet the primary closer to the metering plate size. If someone sold it to you, I'd stuff it back in their rear.
Read Younggun's post and time it like he mentions, should be close. Total timing method is a rotten way to set timing on a street driven car! If you don't know how to adjust stuff do a search, there are literally hundreds of "how do I time my engine" posts.
P.S. Beatniks carb is a much better choice than the one currently in use.
2X:violent1:
sounds like we have established a couple things here.
1. the carb is wrong.
2. you need some solid info about your tune.
Here is what I would do. I would swap on either a new or known good running 750 dp. with mech. secondaries.
I would then address timing. I would start with the cam. i would pull the timing cover and degree the cam. I would make sure it wasn't installed retarded. i would set it up per the cam card.
I would then bolt it all back up and set your initial at between 15-18* and all in by 2500rpm with a total timing of about 35-38* this will require some screwing with the dizzy. those numbers should get you in the ball park.
then go to the carb.
1. set fuel pressure to 6lbs
2. adjust floats till fuel just barely dribble out the sight holes
3. set idle mixture to give you highest vacuum reading at idle
4. as idle increased back off the curb idle screw and redo step 3.
5. check vacume at vacume port on idle. cut # in half and that is size power valve you need in the front.
you should now be in the ball park. this set up should run good and only need light tweaking from then on.
or i could be full of **** but this is exactly what i did with my 383 and it took it from a disappointing heap to a tire melting monster.
