harrisonm
Duh! You're right. I know better than that. Is it too late for me to delete that so nobody will know I made that bonehead mistake!A larger pulley on the PUMP will slow the pump down, not speed it up.
Man, don't sweat it. I do that kinda thing all the time.Duh! You're right. I know better than that. Is it too late for me to delete that so nobody will know I made that bonehead mistake!
cool wheels in your avatar. You must get a pass for those at least.Great news I learned something today, bad news I gave someone bad info on the FB couple weeks ago.
If you believe what you said at the time to be correct, don't sweat it. How do you know what you learn is correct? I think most of what is said, is an opinion, if they truly, believe what they say is correct.Great news I learned something today, bad news I gave someone bad info on the FB couple weeks ago.
Thanks, it's just the one wheel at the moment for fitment testing purposes.cool wheels in your avatar. You must get a pass for those at least.
No myth just fact.
The fact is you need to read up on cooling an engine before putting in your 2 cents. You may be able to run some old, tired engine with no thermostat, but you will not run any high-performance engine that way. Thats like saying you don't need a fan. If the water doesn't stay in long enough to pull out the heat why would you need to cool it at all. I don't mean any disrespect but, just think about it. Or are you being funny. LOL
Here we go again. The faster the heated water goes through the radiator, the water would not be cooled as much, as a slowing flow of water would. So, the water reentering the engine would be hotter going back in, making the thermostat open longer to cool the heated water. The reason for a three core radiator on an AC car. Allowing the heated water to be cooled longer. So, my thinking, slowing down the flow should help, somewhat, but not as good as a larger radiator.Not often I agree with Turk [ post #87 ], but he is 100% correct & I have also posted the same FACTS earlier in this post.
The water-too-fast myth has been debunked by scientific testing. Howard Stewart, the original founder of Stewart Water pumps, built his own water pump dyno/testing rig & tested all this stuff. He was not the only one. When the load on the engine was increased [ causing more heat build up ] with say, air con, car companies used smaller pump pulleys &/or more efficient pumps to pump water FASTER.
