My favorite old saying is Mind over matter, I don't mind and you don't matter.
What size converter would yall recommend for my setup? If I ended up going to trick flow heads one day would that same converter still be applicable? (which I believe have a smaller chamber volume and would raise my compression to about 10.2:1)
I will definitely be going to at least 3.73 or even 3.91s out back this winter.
About 500 miles on the motor. I’ll have to check the carb this weekend. Thank youHow many miles on the engine now.
Is the carburetor opening all the way with the accelerator pedal? Need 2 people to check this.
Are the secondaries opening fully or at all? Maybe you are driving a 440-2bbl.
Thanks for running those calcs. I’m going to run a compression test this weekendThe thing about the CR is………at that high of an elevation, the CR is “effectively” less.
After you do a cranking pressure test and have a real number to look at.
Use the Wallace cranking pressure calculator to see how close it is.
Then change the baro pressure to something that represents being closer to sea level.
The cranking pressure number will go up.
Now, start lowering the CR until the cranking pressure number is pretty close to what you’re seeing from the test.
Whatever CR you used to come up with that result is basically what the effective CR is at your altitude.
Edit-
So I ran the numbers on Wallace…..
Current baro reading(station pressure) at Denver airport is 24.79”.
For a 446, 9.38cr, int closing point of 67abdc, and 24.79” shows 121psi gauge pressure.
At 29.50” it would be 144.
For the gauge to read 121 at 29.50” the CR has to drop down to about 8.25:1
Not sure the details on the build, it wasn’t anything crazy. Big cam, Victor intake, stock heads, fairly “tired” motor. However in retrospect, good engine.How fast was the car with the previous 360 engine? Was it a stock 360 or modified?
Will play a big part in your perception of what is "fast".
3.91 & at least 3000stall converter. Heads would definitely help, but rear gear first is a good idea.What size converter would yall recommend for my setup? If I ended up going to trick flow heads one day would that same converter still be applicable? (which I believe have a smaller chamber volume and would raise my compression to about 10.2:1)
Yeah not hardcore anymore...you're pretty soft and tender. I was joking around with fishmen67 like I do often in many threads. Started in post 19.
That should have been a real pig @ 5400 ft, doesn't sound like a good combo at all and really not hard to beat with a 440.Not sure the details on the build, it wasn’t anything crazy. Big cam, Victor intake, stock heads, fairly “tired” motor. However in retrospect, good engine.
mind you, my mind is the only mind that matters.... that is truly mind over matter lol
no!, IMO, you need more cylinder pressure!Interesting. Seems like all signs are pointing to a cam change
You’re fighting the Altitude. I swapped my Howard’s 238/238 0n 108Lsa 9.5:1 combo that would run 14.2 @ 101 (no traction)with street tires @ 1400’ after we ran at 4600 it wouldn't pull. You need a point of compression or 10-15* less duration. I went deeper 3.55- 4.30 and it was still winded... without more compression. The new combo has 10.8:1 and a 242/242 on 110 and only runs 13.89 in 6000' da.Just did a 360la to 440 swap and honestly thought the 440 was going to be quicker.
Had to cancel my dyno tune appointment tomorrow due to snow. Was wondering if you all see anything that stands out as a weak spot in the build that could be hindering power?
Running 19 initial, 37 total, vac advance, have the curve setup how I want it.
Haven’t touched the carb, Quick fuel said go down 1 jet size (I believe) for every 1,000’ of altitude and I’m at 5,400’ but the plugs look good to me, medium tan color
Everything is brand new:
9.38.1 compression (calculated)
Bored .030 over with Speed Pro forged pistons and moly rings
Completely balanced
Cam and crank tunnels align honed
452 heads stock unported with Howard’s springs specs for the cam
New cam bearings
Howard’s Roller .530 lift, 235/243 dur, 103 CL
Howard’s roller lifters
440 Source roller rockers
Custom Smith Bros push rods
Aluminum 440 source water pump housing and pump
Carter street super m6903 fuel pump
Melling standard oil pump
Edelbrock Performer RPM intake
Quick Fuel Slayer 750cfm carb, vac secondaries, 1” spacer
Lokar stainless braided throttle cable
K&N air cleaner
CVF serpentine system
Stock ignition box and ballast
MSD coil
MSD spark plug wires
Schumacher Tri Y headers
Schumacher engine mounts
Pypes 2.5” stainless exhaust with Street Pro mufflers
Hughes 2500 stall converter
3.23 gears
727 reverse manual valve body
Re-read this. Do you see the plus symbols?Thought I did pretty good. This was supposed to be a budget build (lol yeah right) I almost left the stock pistons and many people recommended bumping it up at least to 9.0. So I got the speed pros. Then I contacted many cam manufacturers. Howard’s had a good reputation and recommended this cam for my motor, street car, 9.38:1 compression, 2500 stall. Think the cars going to get 3.73 or 3.91 gears and call it a day at this point. Sick of throwing money at it.
