i could move the wheels but when i took it out i couldnt spin the shaft
what would cause the clutch pack to bind? i readjusted the bands with no joy. I thought the you were suppose to be able to turn the shaft by hand, is this more of an internal problem?
could the rear band be too tight ? also i was getting a pessure , there has to be an internal issue with the pump it self. Im awaiting a slide hammer to get it out.
Ill look more into a problem with the regulator circuit of the valve body, and readjust the rear band. if the band was to tight not allowing the shaft to be spun by hand would that lead to low pessure in the trans ?
Did you replace the filter, if so, put the old one back on, and try that,, wouldn't be the first time I had a new, defective filter, or new, plugged muffler, but that's another story, just sounds like a pressure prob..
