fresh 904 rebuild, not shifting at all
Not saying your friend made a mistake, could be faulty parts...
I once made a mistake, ... admitted I made a mistake... lol ;-)
Yeah im hoping for the best, the new pump showed up yesterday now im awaiting a new gasket
I m planngin on using the old torque converter to test it because we know that it worked when we took it out. just in case the whole thing stems around a crappy torque converter
Well the inside of the pump was viewed as not out of the normal but we did find a broken ring clip inside which seemed to make a difference. We bench tested and found it to work ok. Then the trans was installed and and upon first start up, the cooling line must hav shifted during the reinstall and i cut the flex line for the cooler, but it also shot trans mission fluid every where. Im thinking the pumping/ pressure issue is not resolved. Ill know more tonight once i switch out the line. thanks everyone.
Ill know more tonight and ill make sure to pass to word along to you guys that have been soo much help to me.
Hopefully i cant get it out on the road tomorow to test it further
