ok , so if it had the performance tci kit in it i should be able to turn it by hand but with the aid of channel locks i should be able to? im going to put in a new pump anyway cause i already ordered one. then i guess pressure tests..
I meant to say --à Could the rear band be too tight causing the it to make the saft hard to turn by hand ? Also I was getting NO pressure, because it would only take 5 qts after rebuild/installation. Does the band issue have anything to do with the lack fo pressure / movement of fluild in the trans ? Lastly is there has any internal issue with the pump it self if the pump ears are presen?.
Wow, I've been reading through the factory service manual and other books that i have and that shows it the best. I proably skimmed over becuase i was thinking it was for 727. ThaAll clearances were checked and double checked during the rebuild, we took our time rebuilding this trans and were trying to rush it to avoid this type of situation.
Ill perform all the air tests that you have listed tonight and go from there. Thanks again for everything!!!!
Forgot to also mention in running a deep pan as well
How about readjusting the throttle pressure lever and arm, would that be related enough to pressure issues ?
