Enjoy it while you can fella. We only have a short time on this rock. Don't lose sight of what's MOST important. You'll get it done.
That was likely mine 6.1 into 72 Demon March 2018. Thread is in hemi swap sectionCan anyone link me to the thread where someone braced there transmission from the inside using some wood and straps? There was so much info on that thread I dont think ill have time to find it for like a week but I want it to move foward freshen my ideas up
Ok it was ur thread and ive read it a few times now and g50 did it to the frame connectors I can recall his too. But there was one more I remember seeing. They used a u shape piece of rectangle tubing for the upper half of the mount and there was something about tubing . I'm dying trying to find it. But i kick this off tomorrowThat was likely mine 6.1 into 72 Demon March 2018. Thread is in hemi swap section
Go man go! Hundred ways to skin this cat! You can't be wrong since there is no OEM on this one! Slash weld and repeat!Ok it was ur thread and ive read it a few times now and g50 did it to the frame connectors I can recall his too. But there was one more I remember seeing. They used a u shape piece of rectangle tubing for the upper half of the mount and there was something about tubing . I'm dying trying to find it. But i kick this off tomorrow
Ok official disclaimer: I am not a mechanic, just a farmer building a hot rod! This is how I did mine, likely not correct way to do it. As I am old and fat I don’t like rolling around on floor. I installed engine with tranny bolted up snug, once installed I took a baseline dimension of tranny tail shaft, then jacked tranny up until I got a hard stop, trying to establish amount of play or droop I had in tranny travel. Then lowered tranny back down to unsupported position again, took another measurement to see if good base line was correct. Then I jacked tranny back up until it was relaxed and engine was not stressing motor mounts. Again shameless plug for Hemi Denny front ends, tranny was supported by jack at this point so that I could play with pitch. Everything felt and looked relaxed and unstressed. Make bracket to fit! Remember some spacer material so you can get bracket in and out. Feel free to PM me anytime and I can give you contact info if it helps you.Ok been running into an issue how can i get ride hieght correct so that I can measure my 1to3 degrees to the rear? Do I just put blocks and stands and make the vehicle level? I have had so many people say they will help, FABO is the only help I've gotten so far you guys rock! Dying to finish the Fab work on my transmission mounts
The wood cribbing sure looks familiar! Hah! Looks like you are rocking it! Zip wheels on a 4 inch grinder are your friend! Great pix and cool build!View attachment 1715395606 View attachment 1715395606 So I've cut the whole brought up transmission mounted it pretty tough to do when you don't lift the car up but I found a way to seems work all right it should look familiar to everyone here hahaha I'm building the transmission mount I'm done taking measurements but not so many pictures I need to slow down it's coming out very well so far for the rfe transmission I have to build a bracket to bring the actual amount for the transmission about 4in back from the original crossmember doesn't seem hard to do it all at this point it's almost all done the measurement I went with is a wee bit large I hope that I did not make it to loose it seems I may have to put a washer on the inside against the original crossmember that I'm mounting to. the first template that I made for the transmission mount was too straight up and down if they have angle they come in towards the bottom and around the pan much nicer if you weld it in the subframe connectors the flex you will see when you make the cut for the transmission will be minimal to make the cut I used a grinder and a cutting wheel a marker and a straightedge however I did weld the subframe connectors prior to this and I definitely recommend that you do on another note how well is your guys's Steady Hand with plasma cutting because everyone I know keeps saying plasma cut apart or plasma cut the mounts out of the plate and as far as I know a band saw and the cutting wheel has been a lot more accurate and cleaner for me I rarely plasma cut.. again thanks to everyone here View attachment 1715395603
Hah, no worries guy we got your back! We will mercilessly heckle you just like we were there, only advantage is we are not drinking all your beer. Remember rule number one when making custom do dads.... heat and beat, paint to match!View attachment 1715399144 View attachment 1715399145
The measurements I had came out good I'm using some bar to hold them open actually some exhaust hanger from work that I cut and hold them open at the perfect measurement while I weld them are they going to come out very nice I have a couple of Builders Dropout from by my side with this because they were supposed to come and help but now I can't even get a response from them so I'll be going in this one hundred percent just with you guys and it'll be trial in there till we get it right
Yeah seems kind of obvious that it was my neighbors as they broke the joining fence to our two houses and are the only ones who could have had a reasonable understanding of what I had but like you said chin up I'll get through it just a lot of projects around here on hold luckily I still have my TIG welder and a couple small items that were in my truckThat sucks! Chin up, things will come around. Any ideas on the burglars?
And so it begins, we promised to heckle you from afar. Pretend we are all sitting in your shop adult beverage in hand, tunes playing in back ground, shop dog at our feet, all of us looking at that empty hole in your car where engine goes. You tell us of your woes with jacked up engine bid and we all start reminiscing about ours. Yep you are getting off cheap! Have another shot shake your head and figure we’ll i will need to work some OT to cover it. We all swear we will help you when day comes to stick motor in. We have all done it Vega!Engine builder gave me a call today added about $675 to the bill apparently when spun a bearing 4 rods are bad and the entire crank is bad so all that needs to be replaced and he added tax so now instead of 1200 I'm at 18 something ouch
