If you start the pull at 2000 that's about all the better it gets. If it makes 100 horse and 150 torque that's what you have at cruising speed. Whats it take to power a 3000# car to 55 mph? 50 horse or less?
Mainly because in a full throttle run aka drag, 0-60 etc... lowest rpm don't matter much even with stock gearing and stall you don't spend much time down there.I really wish those small displacement, small-ish cam dyno tests would start MUCH lower in the RPM range....
...because that's where people drive.
Obviously they had the capacity to show 2000 RPM numbers but for some reason, chose not to.
You can't "assume" the numbers below 3K were also higher.
If it were my car, I'd want off idle numbers.
Especially for a cam upgrade with an advertised power band starting at "idle" or "1500".
That's kinda the whole point of "data".
When your cruising your engine only makes the power needed to maintain that speed or otherwise you’d accelerating.If you start the pull at 2000 that's about all the better it gets. If it makes 100 horse and 150 torque that's what you have at cruising speed. Whats it take to power a 3000# car to 55 mph? 50 horse or less?
From what I understand is a dyno is only good and or easier to setup for a narrow range of rpms.So everyone assumes this is for drag racing at WOT?
I don't think you can make that assumption, either.
This is why all these 318 cam threads have the OP going from stock to .600 lift with a 3K converter and 4.88 gears.
It's like people assume any "performance upgrade" is for the maximum top end increase vis-a-vie ET that the person can afford.
Kind of like people that reply to radio threads with "I don't care about a radio because I want to hear the engine".
I do understand the dyno pulls are basically at WOT.
Why did the tester provide the 2K RPM data on the stock engine?
Why NOT show the changes across the board?
Just seems like a little thing to do that doesn't require very much effort and could be useful.
RPM | TQ | HP |
2,500 | 337 | 161 |
2,600 | 350 | 173 |
2,700 | 357 | 183 |
2,800 | 357 | 190 |
2,900 | 356 | 196 |
3,000 | 351 | 201 |
3,100 | 345 | 204 |
3,200 | 339 | 207 |
3,300 | 343 | 216 |
3,400 | 356 | 230 |
3,500 | 371 | 247 |
3,600 | 385 | 264 |
3,700 | 396 | 279 |
3,800 | 404 | 292 |
3,900 | 410 | 305 |
4,000 | 415 | 316 |
4,100 | 418 | 327 |
4,200 | 420 | 336 |
4,300 | 422 | 345 |
4,400 | 421 | 353 |
4,500 | 420 | 360 |
4,600 | 421 | 369 |
4,700 | 425 | 380 |
4,800 | 426 | 390 |
4,900 | 427 | 398 |
5,000 | 427 | 407 |
5,100 | 427 | 414 |
5,200 | 426 | 421 |
5,300 | 425 | 428 |
5,400 | 423 | 435 |
5,500 | 421 | 440 |
5,600 | 419 | 446 |
5,700 | 417 | 453 |
5,800 | 415 | 458 |
5,900 | 412 | 462 |
6,000 | 407 | 465 |
6,100 | 401 | 466 |
6,200 | 397 | 469 |
6,300 | 393 | 471 |
6,400 | 390 | 475 |
6,500 | 386 | 477 |
323CI SMALL-BLOCK MOPAR | |
Bore: | 3.936-inch |
Stroke: | 3.315-inch |
Displacement: | 323 cubic inches |
Compression ratio: | 10.44:1 |
Camshaft: | COMP solid flat-tappet |
Cam duration: | 247/247 degrees at .050-inch tappet rise |
Valve lift: | .622-/.597-inch |
Rocker ratio: | Harland Sharp 1.7:1 intake; Crane 1.6:1 exhaust |
Lobe separation: | 105 degrees |
Intake centerline: | 99 degrees |
Top ring: | .043-inch Speed Pro barrel face |
Top ring gap: | .018-inch |
Second ring: | .063 Speed Pro, scraper |
Second ring gap: | .018-inch |
Oil ring: | .187-inch |
Piston: | Diamond dome, zero cc effective volume |
Block: | OEM roller 318 |
Crankshaft: | OEM forged 340 |
Rods: | Scat SBC 6.200-inch I-beam |
Main journal: | 2.490-inch |
Main bearing clearance: | .0022-inch |
Rod Journal: | 2.100 inch |
Rod bearing clearance: | .0022-inch |
Cylinder head: | Mopar Performance R/T Magnum |
Intake valve diameter: | 2.020-inch |
Exhaust valve diameter: | 1.600-inch |
Intake manifold: | Professional Products |
dual-plane | |
Carburetor: | RM Competition modified Holley 950 HP |
Header: | Hooker 1-5/8-inch primaries |
Ignition: | MSD 6AL |
Damper: | Professional Products |
Water pump: | Professional Products small-block Chevy |
So to clarify, cars that what people generally call soft down low is from improper tuning? would make sense cause even a big cam low cr engines makes many times more than enough power down low to drive a car.A water brake or even an inertia dyno is NOT for most driveablity issues. That’s not what it’s for. So why abuse a tool for something it’s not designed for?
It’s amazing the number of guys who think what happens at 2000 RPM is critical, or really even important. What matters down that low is mostly a tune up issue.
How well the engine transitions from the idle circuit to the transfer slots and then on to the mains is far more critical that torque. It’s mind boggling how guys get this wrong.
That’s a cam to increase mileage for sure!The “no matter what certain to make a performance improvement in a high geared low compression 318.” Works well with any of the 318 port intakes.
Mile-A-Mor Cam [3901M] - $246.00 : ISKY Racing Cams, Do It Right
I think you are confusing two aspects of this and it starts with what YR is saying and how others are just simply wondering about a low dyno pull rpm test in addition to cam size, and I note see engine usage.So to clarify, cars that what people generally call soft down low is from improper tuning? would make sense cause even a big cam low cr engines makes many times more than enough power down low to drive a car.
As for what your saying about torque would be like, If you take pushing your car as an example torque is like the force of you pushing, rpm is like the steps you take, power is both combined, and the more steps a second, quicker you go.
It actually makes a pretty nice performance improvement over the stock (usually .373 to .386 lift) cam, too. It sounds nearly stock and makes for a nice sleeper through quiet mufflers.
