It's almost been 2 years, FILE....:rambo:.........:nike:
Problem is he makes somthing that is unique. If anyone wants to go into the header business in Ontario let me know. What is stopping someone?Does he own the pattern? Are the Laysons units the same?There seems to be lots of talk about this guy. If he's that bad stop buying from him. It's simple.
Great idea, the need has been established.OK,
first of all how much was Laysons asking for headers, I called them and they actually called back and they said they did not know anything about them!???
I may be a position in a few months to start a business and was actually thinking about the header situation. I was thinking about a set of smallblock midlength headers with 3/8" flanges, regular steel, for $350. If ceramic coating was desired I would shunt that through Cuda Chick.
Thoughts?
Andrew
OK,
Thoughts?
Andrew
i said DO NOT!!!i repeat DO NOT send that $&(@ ^@(&%! any money when ordering headers from him. C.O.D only with him...
I spent several hours talking with a GM exhaust engineer and the guy took the picture of Harolds design and painstakingly plugged it into his simulator at the GM design center.....harolds design actually causes damage and based on the TRI Y the flow, mix & pull ( exhaust synergy ) whatever the hell that is, comes out to be below that of a standard 340 cast iron manifold in fact its worse that that OF A standard 318 cast manifold!!!
