1wild&crazyguy
Banned
enrichens at wot/vac rating, it's power with economy.
if you want to plug it, up the jets 8-10 sizes, and get poor milage.
where do you buy these full groove mains?
I used to hear about 413 full groove mains....
you need to check you idle vac in gear and divide by 2 to get the proper pv rating.i run a little on the high side,my vac in gear is about 10.5 and i run a 6.5 pv.so when tuning would u first just "drive" not accelerating to see if primary jetting is correct and then accelerate with secondaries disabled?
same for testing secondaries?? minus disabling primaries of course
and my pv was a 6.5. kinda high because my idle vac is only 11 or so right?
the power valve opens at a given vacum drop/rate and feeds the main system, in your case the pv would open at or below 6.5 manifold vac.
at cruise there is a lot of vacum, too much for the pv to open.
to find the correct rated PV is to know the manifold vac reading at idle in gear, a/t uses the half of of the manifold vac reading with m/t being only 2 rates below manifold vac reading.
so if you have 8in vac at idle in gear [a/t] you would want a 4.5 power valve, which is half [pretty much] of the 8 in reading.
jetting is simply going from ootb, considering elevation, and leaning till a surge at cruise then go richer 2 jet sizes-primary.
If you have a PV in both pri/sec, then you just square up the jetting=same pri/sec. If you only run 1 in the primary, then go 8 jets bigger on the secondary.
ah geeze!!! well i dont have a degree wheel and piston tdc stopper, i know how to do it just don't have those tools
you should be around 5.5 or a 6.5......it's half the reading.
google it man...just find holley cross reference and look for the numbers listed that are on the choke horn or box it came in.
It'll tell you jetting/pv/shooter/cam/bleeds....
it could be 66/73 or 66/76 jetting, most likely the 66/73.
what numbers if any are after the 4776c on the front of the choke tower?
yea hada top ring break so having the block re honed, and decked for more comp, and upgrading some stuff...So, is this the build that is seen in your video?
Damn,this was some great reading !!! Now if I could just decipher it all I'd be in luck !!Trying to get as much info as I can for when I do my next /6 project ! Here soon I'm hoping for !Anyone in theMelbourne area in case I need more techno advise ??
WOW!!! that was 48 seconds of my life wasted.
I wouldn't have done a thing to the second ring, but the amount you opened the gap won't matter anyways.
