slantsixdan
Yes I was wondering about the knurled area where the seal touches, that knurling is supposed to wind the oil back into the engine as the crank is turning.
Gus Wilson had words to say on that subject.
For awhile there was a special anti-leak rear main bearing offered for the Slant-6. Had two diagonal grooves cut into the bearing surface. As far as I know it's been unavailable for a long time, but—again—it should be possible to get a reasonably dry rear main seal with careful attention to parts selection and install technique, and without any special rear main bearing.
