chryslerfat
So far my best yield yet of the 8 years I have been doing it. Prices are at a 3 year high right now but could fall.How's it looking so far CF? You getting a good crop this year?
I'm happy for ya buddy, hope the prices stay up. Around here if the farmer has a good year so does the rest of us.So far my best yield yet of the 8 years I have been doing it. Prices are at a 3 year high right now but could fall.
Seems like what happens to you we get the same the next day.Looks like this week should be not too bad here, except for Monday.
Well, cam sensor did not fix the old dodge truck. It's so weird cause all of the testing I've done points to that sensor, not that I'm well rehearsed at any of this. If I hotwire the coil, it runs.
Knocked the garden in the head today. No big job. Very little rain today.
I got all of those voltage references earlier. All seemed within spec. Would you re-read your post Biff cause it kinda don't make sense to me as far as the 5 volt reference. You mention map sensor earlier. Dodge is kinda tricky with that one. Starting to look like a parts truck again LOL. I REALLY appreciate the help.1. Check for 8-9.5 volts on the Orange wire at the distributor pick-up connector.
2. If 8-9.5 volts is present on the Orange wire, unplug the Manifold Absolute Pressure (MAP) sensor.
3. Check the Violet/White wire for 5 volts.
4. If the 5-volts reference is OK now, replace the MAP sensor.
5. If still no 5 volts, snip the Violet/White wire near the PCM at pin 6.
6. Check for 5 volts on the snipped wire out of the PCM.
7. If still no 5 volts, check the power supplies at the PCM on the Red wire at pin 3 and the Dark Blue wire at pin 9.
8. If the power supplies are OK, the PCM is faulty.
Okay I get the 5 volt thing now that I re read it. I'LL try that tommorow1. Check for 8-9.5 volts on the Orange wire at the distributor pick-up connector.
You would think the PCM is okay if it's kicking out codes.1. Check for 8-9.5 volts on the Orange wire at the distributor pick-up connector.
Yes it should it will be a corroded wire in the harnes I suspectYou would think the PCM is okay if it's kicking out codes.
ASD is working. I get a quick little light on the test light on the blue with black tracer when I cycle the ignition. I get continuity from there to the coil. About 30 ohms on the meter. I don't get the quick little light at the coil. Nothing when I crank at the ASD blue / black. Seems like the new pick-up in the dizzy is bad. I'll have to dig deeper into the MAP sensor. Thanks again.Sorry bp , I just copied it from identafix , I would still lean to the ASD relay,because it runs when you jump the coil . Let me know tomorrow
At the coil, the Green/Black wire provides the power from the ASD Relay and the Black/Grey wire goes to the Coil Driver circuit at the Powertrain Control Module (PCM).
I have been fooled with my meter I now use an old headlight bulb to see if the circuit can carry voltageASD is working. I get a quick little light on the test light on the blue with black tracer when I cycle the ignition. I get continuity from there to the coil. About 30 ohms on the meter. I don't get the quick little light at the coil. Nothing when I crank at the ASD blue / black. Seems like the new pick-up in the dizzy is bad. I'll have to dig deeper into the MAP sensor. Thanks again.
Is that BAD?We're close to 1600 pages.
Or is that GOOD?Is that BAD?
Probably bad for FABO bandwidth LOL.Or is that GOOD?
I need to subscribe.Probably bad for FABO bandwidth LOL.
Maybe next paycheck. LOLI need to subscribe.
That was a bit of a joke Smokey. Hence all of my needless posts. LOLNot bad at all. One of my word games on another forum is close to 1400.
