Bells are made on the tranny. Amc spirit, concord, some postal jeeps 2 wheel drive, etc. early to mid 80's with a 2.5 then have the 904 built. No different than all the Chinese 451's and other mopar builds and swaps. Keep it mopar..... Yea,lol. Most built mopars out there are 1/4 or more Chinese. LS and mopar,,, good swap imo.do you remember year/model/motor it came in?
I looked into it and saw a an 82 AMC Eagle 2.4 with a 904, but didn't see anything on there for it.
are the bell housings swappable?
http://www.carparts.com/results/?N=0&Nr=AND(universal:0)&PN=0+7514&VN=4294959959+4294966030+4294961449+4294967027+4294966772&universal=0
Thanks for being one of the few with an open mind. Most hemis in the junk yard are still way more expensive to buy than an LS. Mods are a lot more too. Mopar ecms are not user friendly. That why guys try and use LS ecms and succeed. If you carb a hemi compare just the manifold cost to an LS. Install, bout the same except exhaust. Again LS is less than hemi,and better fit. I looked at every reasonable way to do a mopar, being a past mopar guy myself. The LS just makes more since to ME in power,mpg, handling and mods for money spent. Not tryin to rain on mopars parade. Just MY opinion and research. I still have trouble with the idea of LS in my 67 cuda,but makes since to meWhere is the cost savings. In LS3 over GIII. Is it motor and trans and tuning. Can it be done on stock k member. Seems like most mods are the same. Fuel delivery, headers, kmember. Not putting it down at all but is the difference that big. It's been several years since I did my swap. I know there is a lot more out there for it now and a lot more in the junk yard.
No offense but I don't have time to post the numbers as I wasn't doing this for anyone else. It's easy. Go to jegs or summit. Then go to huges or Mancini. Even 440 source and scat. Compare prices. But look at mpg and power made for money spent. I'm not tryin to Win anyone over,it's just me. Btw, LS crate is usually lots less.Show the numbers. Is the crate Ls a lot cheaper. This very interesting not that I would do it in my Cuda but for a D100 this would be something I might do. I've seen the chevy guys do Tahoe swaps after they changed intakes and other mods to the engine seems they spent just as much
LMAO!That's what I was doing. I already have a well built 6.2 ls3 to go in or I have to build my 440's ,400, or 360. 67 cuda with 318/904. Don't have the money to Build em,so swap in the gm.
True. I also heard that LS to s-10 swap headers fit well. I got a 585hp LS3 that's built or I'd have to build my mopars. So I'll use what I got. With the power,mpg, and handling ( it's aluminum) it otta be worth the price of admission. We'll see. 67 cuda LS. I can here the purists already...Also, the LSx can fit around the stock suspension components quite nicely. Tight, but doable.
Here's a under car shot of Chris Shawvers 69 LSx Barracuda.
Or, with the money you save by going with a salvaged LSx and not rebuilding a classic Small Block or Big Block mopar engine and not completely rebuilding the OEM front end on your car...you could buy a HemiDenny or AlterKtion rack and pinion front end. This way you can use any number of the very inexpensive ($150 and up) 2010-2015 Camaro stainless LSx headers and still be money ahead at the end of the build. Things to consider.
After reading the last round of worthy replies, and not the childish insulting attempts....True. I also heard that LS to s-10 swap headers fit well. I got a 585hp LS3 that's built or I'd have to build my mopars. So I'll use what I got. With the power,mpg, and handling ( it's aluminum) it otta be worth the price of admission. We'll see. 67 cuda LS. I can here the purists already...
You thought out you build,but still with that the LS is less. Don't have to do k member. LS harness is less,headers are less,etc. Then if you want to modify, it's less. I'm not tryin to step on anyone's toes, but there are others with my same interest. If I get flamed, I'll flame back. I won't go away.Not $700 on TTI. And that was 7 years ago. Here's roughly what I spent. 700 headers. $2500 04 truck motor/tranny. $75 ECM. 1200 harness. $700 headers. $800 fuel tank and pump. $250 oil pan. $4000 alterkation front end. $140 radiator. $75 fan/shroud. $250 for SRT intake adapters. $50 SRT8 intake.(great deal right place right time) $175 pedal. $175. Throttle body. Holy crap that's a lot haven't. Added up in along time. That is not all the small things I under $25 that add up. .
I'm still waiting for that long tube cross ram you are gonna give me for my project to hack upThank you Logan.
A lot gets lost in type. As I said before, a LS swap is something I would not do but I do not fault anyone in doing what they want to do to there car.
Your car your way! It is after all, your car and your money that is hard earned so spend it as you see fit.
Best of luck with your project Logan.
No way on the 8.75. I have a Dana 60 small tube I was thinking about but I'd like to know how you accomplished the 8.8? I have access to an 8.8 from a explorer, 3:73 and posi with discs. How much power do they hold? I'm not sure how to create a build page. I assume I just start a post and apply pictures?Cuda620 do it and make a build page. I will definitely follow it. I think it could be done half the cost with some big hp gains a lot cheaper from what I just looked at on the LS sites. Do the 8.8 swap too that's what I did $230 and disc brakes. 373 limited slip try building an 8 3/4 for an Abody with that money.
