j par
Well-hung Member
Got coffee, it's a start....Getter done.
Agreed but again it's just a start it's not the whole day drinking coffee! LOLYOU ain't getting chit done sittin on ya *** drinkin coffee!!!!
It's actually the torsion bars that get really close, but it touches the milodon pan. Which good Lord, don't even get me started with that pile of crap.Uh, how the hell dose your steering pass those headers?
I hope that's just the angle of the pic? But dam that looks close. I thought my headers were tight...
Please see my thread here on header wrap pros and cons.Just a silly question here. Why are your headers wrapped like a mummy?
Turned on the heat and heading out to the garage to get something done and guess what I'm going to start? LOL pulling them damn headers back out and spray painting them. Maybe I'll get back on that headliner a little bit also. I don't really want to start connecting things underneath until I get the headers in. I don't want the z bar or the starter or any of that stuff in the way of that driver side. It's a pain with everything out of the way. When I read the directions on the spray can it didn't say anything about cure time except for that cures after it's been brought up to 400° which I don't see that happening anytime soon. So I guess I'll just spray paint them and hope they are dry enough to install.
Yeah holding in the water and rusted and all that is pretty much a problem for a daily Street driven car. One that is garage kept and only brought out on nice days is not going to have any moisture problems or resting likely. They're just cheap junk Summit headers I've had for way too long that are still working just fine that I'm kind of putting a little lipstick on and for the first time I'm putting a hood on the car so also to keep temperatures down would be nice under the hood. But really it's mostly cosmetic. Also something I've never tried. Likely in a couple of years these will be replaced with something nice for the first time anyways. Trying some new stuff and kind of using what I have.Can't find where you posted the reason for wrapping those headers like a mummy. So far are you mentioned you were going to but not a reason for doing it. I thought rapping them like that held moisture and rusted the tubes out. What is the post nimber explaining doing this?
Okay going at it this morning. The carpet out and looking at the four speed hump here and I remember I have a little fabrication to do here. It looks like I was pretty anxious to get that vertigate in there, but luckily I saved the piece I cut out. I'll get it all tacked up later. I want to get underneath and get some of this linkage hooked up and get the motor mounts and everything all tight. I might even be able to get the Driveline back in also. I'll start with the mini starter, sounds like a good place to start...
IN...So you are putting the stick back in?
IN...
The transmission been in, but I'm just getting all the shifting linkage and clutch hooked up.
Okay I should be able to turn Focus off the headliner and within the next day or so. And back on to some more reconfiguration. I've already looked at what's coming up on my plate next and it looks like SPAGHETTI!
Now if you trace your wires in that picture real closely LOL if you look where that squiggly piece of metal that I have Holden the whole operation meets the wood bench, you'll see a piece of aluminum with two finger tighteners and what looks like a strip of two-sided tape on it? The two-step buttons connected to that! LOL!WHOLE-EEEEEEEEEEEE-CRAP. That's a mess.
