Last one, I don't agree with you and you don't seem like your gonna agree with us, lets just focus on the OP build, he's not stroking it anyways.273,
This is for you. I know from your posts that you are quite knowledgeable. Not wasting time with Turk, he doesn't know how an air bleed works.
Combustion creates pressure, psi, my eg.. Was a 1000 psi (the psi of a average engine, full throttle) not a 1000 lbs of force, so the force from the piston would be F = P x A, larger piston more area for pressure to be applied = greater force to the rod.You are confusing force with pressure [ loading ]. Look at the formula in post #112. Pressure= force divided by area [ not multiplied ].
In post #91, you said energy can neither be created or destroyed. 100% correct
In post #114, you used an example of 1000 lbs of force in the com chamber. Let's work with that.
