It's an early 70s "BH" casting. Supposedly they are supposed to be a heavier, thicker casting. This one certainly is.That should take a good size over bore, is it a 60s or a later block.
That's the whole reason boring adds power. Period.Great logic if you’re driving nails. There is a formula for that.
It’s:
P
L
A
N
P is PRESSURE
L is length
A is AREA
N is dammit I forget.
Anyway, it’s PRESSURE exerting FORCE on the AREA of the piston.
So…if you put 100 pounds of pressure on a 4 inch piston and that same 100 pounds on a 5 inch piston.
Which makes more power?
It's 100 lbs per square inch not a 100 lbs divided by the area in square inches.Turk,
I will answer your question first. Post #98. Both engines will make the SAME POWER.
That is because both pistons have the same total force applied [ 100 lbs ] ; what will be different is the lbs per square inch. The respective areas of a 4 & 5 inch piston are 12.6 & 19.6 sq in.
The pressure on the 5" piston is 5.1 lbs/ sq in; on the 4" piston it is 7.9 lb/ sq in....which adds up to total of 100 lbs. Any other scenario would mean energy is being created.....
You can make as many dumb analogies as you want, your just wrong.273,
Now you are introducing red herrings. Your original story, which was wrong, was that a bigger piston exerted more force because of it's greater area.
I do not know how many examples are needed until the message sinks in. So I will try some humour....
There is a lump of dog s**t on your patio. You get the garden hose to get rid of it. You adjust the hose nozzle for a concentrated stream...& blast away the mess. Had you used a fan pattern with the hose, it would not have removed the s**t. The pressure was the same in each case, but spread over a wider area with the fan pattern, & therefore less force per unit of area.
273,
Post 106. Nope wrong again. Confusing weight with pressure.
As I said earlier, if big piston areas were able to perform your magical idea, it would be reallllllllllllly easy to make reallllllllly big HP........& we would see lots of engines with huge pistons. But we are not...
That's not even the same comparison to a piston in a piston driven engine. I can't believe you're this obtuse.Maybe this will do it. Force per unit area. The coin sinks into the plasticine further when pushed end-on because it has more pressure with less the area.
Get it now Turk or are you too dumb???? Get it now 273???
Say the combustion is 1000 psi, you got a 1000 psi pressing against all the surfaces inside the chamber which includes the total top of the piston aka piston area, so each square inch of the piston is getting a 1000 psi.Maybe this will do it. Force per unit area. The coin sinks into the plasticine further when pushed end-on because it has more pressure with less the area.
sell all three sets to offset the cost of new aluminum heads.Okay update time. I have 2 sets of 906 heads, and 1 set of 516 heads. Suggestions?
Alu- min-ium heads are so,,,, costly. Tell me true. Are they worth the money, seriously?sell all three sets to offset the cost of new aluminum heads.
the short answer: it dependsAlu- min-ium heads are so,,,, costly. Tell me true. Are they worth the money, seriously?
Machine shop prices can vary greatly depending on where you are.Alu- min-ium heads are so,,,, costly.
the longer answer is: what is your ultimate intended goal? the alum heads probably have more room to grow, or will support a lot more power in out of the box form vs stock 906/915 heads. an aftermarket head is generally machined for larger valve springs, larger valves, hardened exhaust seats, updated valve guides and seals.
so basically, all of the stuff you'd need (and should) be doing to update a factory head for not only performance but also general use and longevity. then, add in standardized chambers and flow numbers that rival steel heads that have already been ported.
i'd bet dollars to donuts if you sat down and did the math, new alum heads would be darn near the same price as a set of full worked over 906's by the time the dust settled.
Gentlemen, then suggest a head and let's see if I can go that way or not.Machine shop prices can vary greatly depending on where you are.
At my shop, for parts and labor……it’s pretty easy to spend as much reworking 50+ year old factory iron as what the more budget friendly aluminum heads cost.
