ok so now If you were looking at doing a cam upgrade u need to consider alot of things...
what is the car going to used for? 1/4, 1/8,daily driving, race only????
do you have the money to upgrade to a new (correct) converter?? (If auto)
stump puller or top end charge?
now for why i ask!
the things u always hear are lift, duration, LSA...
so to break it down
lift is how far the valve opens off the seat, the more lift the more air that can flow around it into the cyl, but if you open the valve to much u can hurt air flow (testing on flow bench tells you this)
duration is how long the valve is off the seat. now there are lots of ways people mesure duration, advertised, @ .050, even @ .020, most @.050 tho... so anyways when you hear a cam has 246*(degrees) @ .050 duration thats a healthy, lumpy, high idle cam, also means that it is more efficent at higher rpms, so the low end (torque) is hurt... so low @ .050 duration means more low end rpm range power and higher @ .050 duration is higher in the rpm range
LSA, or Lobe Seperation angle, is how far the intake lobe center line and exhaust lobe center line are apart, if i remember big displacement motors/blower motors like more LSA, 112*, where small motor like the 225 SL6 like 104-106.
got it?
