Uh thanks, I think... ;)
I was laying under it this morning thinking this is my last build
Last Build? Not - did you forget already my Duster is your next project? So stop dickin' around and finish your "second to the last project". :-D
After following your work here I've taken a change in the direction of my Duster. Here's what lies ahead so you can start gathering parts and get right to it when I drop my car off:
1 - Obviously - straight axel.
2 - We won't call it a gasser though, it'll be a "fuel-er" cause the "oil burner" Cummins 24 valve turbo, all electronics (makes 525 HP + 1000 TQ to the rear wheels) and built auto trans, which I'll send along with the body when I ship it to you.
3 - I have an 8 3/4 rear for it, but in case you prefer I'll send the Dana 70 (3:54 Locked) rear from the truck the Cummins is coming out of.
4 - To make things easier on you - I have a "new" full floor (rail to rail, toe-board to back side of the rear seat riser) from AMD. I'll send along about 20 pieces of Hospital bed frames (1" X 2" rectangular stock X at least 8' long) for frame connectors and cross members you'll need.
5 - I'll leave the rest up to your "Artistic" flavors.
:toothy10:
Will be one interesting/wild car when you're done . . .
Seriously, "your last build" !?!??!! What are you like 90 years old? Even if you are you've probably still got at least another 4 - 5 builds left before talent like yours can't be utilized anymore.
Keep up the good work, and don't forget to let me know where to ship the above 1 - 4 items so you can get started when your done with your car. :-D
Look forward to next update - enjoy the day.:cheers:
