Hey Doug,
I have been tossing the same ideas around also for the 67 Dart I am about to get painted.
I will install the 318/402 combo in it and put a stout 904 behind it and drive it like that maybe abuse it a bit with some NOS while I put together a BOOSTED 360CI motor. RHS Headed most likely Stock Block, forged internals, girdle, cometic gaskets, head studs and probably a blow thru carb unless the EFI is reasonably priced with air to water intercooler & Water/Meth injection. I am tossed between single or TT set up. You can get the T60/70 Turbos for a reasonable price for the twin set up. 10-15 lbs of boost it should live, crank it up to 20-25 lbs and something will prob give, I dont know. How much boost does SDCE say a prepped block partial filled will take? There are alot of mixed views on the subject for sure. We need to figure it out. There is a member here that use to have a SBC TT with the smaller T3 Turbos that would run in the 8's all day long at 377CI, if I remember correctly. That is Hauling ***. You would probably get 15mpg with efi until you got on it. WHY NOT A MOPAR!!
