Kenflo
Looking at new pulleys and came across the CVF serpentine conversion. There is no info on their web site regarding ratio or pulley diameter (I plan on calling them Monday). I did read a post on here saying the crank pulley is 6.25 and water pump pulley is 5.125 making the ratio 1:22 overdriven. I do not have AC and plan on using the Mopar performance 4140063 5 blade fan with 2947 Hayden clutch along with a high volume water pump. My main concern (and may not even be a concern) is this combo could cause issues like over heating or damage to the fan/clutch?
My current set up is basically factory pulleys 318/340 spec with 0.95:1 water pump ratio. Does overdriving the water pump/fan in a non ac car cause issues? Or is it a good thing?
