208Dart
Hey all,
Been working on my painless installation over the last few weeks and have gotten to the point of testing the system. Car was gutted before I got it.
I have a new turn signal switch from classic industries as well as a new ignition switch from same place.
I initially had a problem with my headlight switch but dug into the factory wiring diagrams a bit more and got it working perfectly. I replaced my ammeter with an aftermarket volt meter.
I've replaced or cleaned all the bulb sockets for signal and parking lights and replaced all the bulbs.
Things that work:
Running lights turn on with first pull of light switch. TURN SIGNAL INDICATORS LIGHT UP ON DASH with this engagement. They turn off when headlights are turned on however. This makes sense to me since the signal bulbs are on in the "running light" mode. Might be wrong though.
Brake lights work in all light settings.
Hazard lights flash and work perfectly.
Headlights turn on, high beams and low beams work, dash lights turn on, volt gauge reads correctly.
I've grounded my steering column to the column mounting bolt.
Fuses are all good.
If I connect a ground wire to what I'll call the horn plunger I can hear the horn relay click. Horn is not installed at this time.
I've traced my wiring diagrams and I cannot figure out what might be hooked up incorrectly.
I have replaced the turn signal connector with some modern pigtails because I was unable to source an original connector.
I have the terminals listed 1 through 8 on the connector. Here's what I have them labeled as and what they're connected to:
Terminal 1: Horn Ground - connected to painless wire 963 "horn switch"
Terminal 2: Left Turn - connected to painless wire 926 "left front turn signal"
Terminal 3: Right Turn - Connected to painless 925 "right front turn signal"
Terminal 4: Emergency Flasher - Connected to painless 951 "Hazard B+"
Terminal 5: Turn signal Flasher - Connected to painless 952 "Turn signal flasher B+"
Terminal 6: Left rear turn signal - connected to painless 949 "left rear turn signal"
Terminal 7: Right rear turn signal - connected to painless 948 "right rear turn signal"
Terminal 8: Brake switch - connected to painless 918 (brake switch). There were two 918 wires in this section, I connected both of them.
I'm at a bit of a loss at this point. If anyone has any tips or ways to test my signal switch that would be great! I'm good at tracing diagrams but I'm a novice at electrical in general. Can post some pics from my phone after posting.
TIA!
Mike
Things that work:
Fuses are all good.
TIA!
Mike
