fstfish66
looks intresting,, ide think you may need a big carb to keep it from running lean,,,,
spool up? wait for torque? :-D
http://www.youtube.com/watch?v=tk0FAlRznic
Here's Mike talking about his first pass at shakedown at e-town...his car has only 5 or so passes on the new suspension and turbo set up before going to the shakedown...funny part is for this pass, Scott took power out of it and he still hauled ***! 166 mph...8.35's....not bad for a little 382 cid small block.
:-D
http://www.youtube.com/watch?v=JkzbNngauLQ
pics when you get it sounds intresting
looks great,,,dont see why the dizzy would interfere,,but if you plan on a vacuum advance i think it will hit,,,
what is the square boss behind the blower??? a pop off valve ??or water out let for the heater??
any pics of the car you plan on putting this motor in to???
I've been chokin' on those TINY little 750.s for wayyyyyyyyyyyyy too long.Got me a pair of BIG 'tators so 5lbs of boost will no longer be my limit8)Feast yer eyes,time to turn the wick WAY UP!!:toothy10:I'll sneek in here for a while:bootysha:Boost is great8)8)
this litle streetcruiser that will hopefully se the track this summer
not sure what i will have to do to the scoop yet but from the little measuring i have done i may get away with the sixpack scoop if i make an oddball aircleaner![]()
Thanks!! The SV1's are actually a little shorter in height than a regular Dominator.Hemi-itis if those SV-1s turn out to be a restricion then its hopeless, very nice looking carbs! i did look at those before choosing a normal dominator due to hood clearence isues! now go make that hemi run for what its worth!
very kool. hard to imagine muscle cars in other countries,but very kool,,,dont think you will be able to use the 6 pak scoop,depending on the size belt and pullys you use, the top pully will be close or stick out of the hood,,, what is the street scene like over there???
You are absolutlely right,the blade wide open is 1 3/4 inches beond the carb base:read2: I can't wait 'till spring!!!!!!!!!yeah i noticed that part and i got real intrested then i started thinking of how close to the screws in the supercharger that giant throttle blade would be and realised i would have needed a spacer to be able to run it![]()
thanksthinking the same, if i get away with it it will be very close and it depends on how long snout and the size of the top pulley like you say, the belt will be a 12rib belt and i will aim for a fairly small pulley, im realy trying to make this as stealty as it can be,these blowers are not very loud during low load situations,however they totaly scream under full boast
there is lots of muscelacars over here everything from beat up darts to HEMIs and LS6 chevys to BOSS mustangs of course the more extreme stuff is kind of rare but they are out thereif you ever end up visiting sweden there is a pretty big car show in Västerås called "power big meet" lots of any kind of american cars to see
the streetscene is out of control to be honest some serious stuff is out there late at night for some cups as well as one night only meetings basicly run what you brung and hope you brought enough i got nothing on those people lots of it can be found on youtube if you search for "birka cup", "stockholm open" or "valhalla cup"
the other streetscene is just cruisenights that can be very nice![]()
very kool,,reallly intresting u having cruise nights there,,,cant wait to hear how your motor runs when u get it all together and in the car,,, here is a shot of my hood shut,,maybe u can see the front pully
I can't imagine what changin' plugs must be like!!!!Sure would be easier if the plug holes were in the middle of the valve cover8)
Sounds easy enough:read2:Long extension and a swivel takes care if it pretty easily or you can just remove the exhaust side out of the turbo by loosening 2 V Band Flanges and in less than 2 minutes you can have a clear shot at it if you wanted. The Drives side is easier than the passenger for sure.
i hope you plan on running a dampener ?? the lower pully location is going to determine the length of the snount of the blower drive,,
also if you havent yet, looks like your motor is together,,?? you should have the crank cut 180degrees for a double key way,and the same in your balancer,,,some guys dont use a balancer and just run a lower hub for the blower belt pully,,,claiming the belt takes up all the vibrations,,
the double keyed crank helps it from having the belt drive from twisting the front of the crank offf,,,
what kind of boost are u planning on??? mine is a street car my pullys are at 6% under driven,,,7.76 actuall compression and make 13 pounds of boost,,
absolutly a damper is a must,will reuse my old thrusted fluiddamper that is from the stoneage it has never given me any trouble and i hope it wont start acting up nowbut will try to put the blower belt as close to the damper as possboble if i can make it work like that and have the powerstearing and alternatorbelt outside the blower belt,we will se if that works or not..
i have thought alot about putting an extra keyway in the crank but shortblock is toghether now and in absolutely worst case i have a spare crank if something bad happens to the one i have now and im only planing on running about 8pounds of boost for a start since i know my poor stockblock is the biggest limitation and better to learn how to tune a blown engine before starting to push some bigger boost# but i would not be surpised if i end up at 15lbs of boost sometime late in the summer,the important part is to be faster than my friends nova for a while before doing something stupid and blow the engine,this is also a streetcarbut with alot more compression on E85
dont think you will be able to get the blower belt behind the water pump and alt belts,,the blower belt would probably hit the water pump,and you would have the water pump pully spaced out so far that the bearings and seal in the water pump would wear out,, ill see if i have a pic of my belt set up ,maybe give you an idea of whats its going to look like,, i also have a fluid dampener,,and i have a custom made lower spacer/pully made, you have to mount the water pump pully and alternator to get the correct deminsion for the V belt groove when you have it made,,
