mikesduster
WELCOME to the site!!!!!! Your combo runs GOOD!!!!
Nice combo.
Are the correct springs on the head for that cam. It seems a bit short on RPM.
I see you all ready went with more stall, which is good. You should see a nice drop in ET.
What is your track Alt. I just noticed your in Az. Around here, near the water, kind of, LOL in E-town N.J., alot of guys are knockin down good times with a similar combo. A slight faster. (Not raggin on ya)
Thanks! It took me 5 years to get together, family comes first. I have been out of racing for 20 years, feels good to get back out and let it loose!WELCOME to the site!!!!!! Your combo runs GOOD!!!!
Hi I am new to FABO. Have watched this thread a while and decided to join in.
Even though this is not a 3.38 stroke combo, here goes. My original goal for car was to get into 12.80s but the car will do that easily, new goal is 11s.
1971 Dodge Demon, all steel, factory glass, no carpet(yet), 6point rollbar, subframe connectors. Have removed 150# from front,(light brakes, man steering, light wheels. I plan on going NHRA Stock class next year. Car is new, still tuning. Run on pump premium gas only.
My weight, 150#
Car weight 3100#
Gears, Dana60 4.56
Tires, MT 29.5/9/15 slicks 28 in front
3000 stall converter
904 w/low gearset
Engine is Mopar 380/360 shortblock out of bag no prep.($1000) Heads stock untouched 340 from Aerohead.($500 pair)
9.0 to 1 comp
508\292 hyd cam
750 Proform carb
TTI stepped headers
Caltrac Chassis
Last outing it was 104 deg out at 7 PM with 60% humidity.
Results were 12.40 - 12.41 @ 108.6 MPH all night. 60' @ 1.66-1.68
I shift at 5800 and run thru traps at 6100. I am getting valve float above 6000 so that is to be addressed. I just changed to ATI 8" 4500 stall, hope to see 11s soon, once the weather cools down.
I have enjoyed seeing how many different ways people use to acheive the same results, cool!
Chuck.
Thanks Rumblefish! I was not expecting to gain that much! It was cool.LOL me too, now, you gotta move your entire post with upgrades over to the 11 sec. zone! Ha-ray!
I wiped the number one intake lobe off of my Comp Cams camshaft. I installed a Mopar purple shaft 284-484" camshaft and lifters. I ran an 8.08 at 83.5 at Rockingham with it. My 60' times were 1.76 and my 330' times were 5.16. Everything else in my combo remains the same.1975 Duster with no front bumper or carpet, steel 14 x 4.5 front and 15 x 8 rear wheels, 360/904, 8.75 rear end, full of fuel and 2 14 x 5.5 rallye wheels with 215/70 tires on them in the trunk. Weight 3042, with driver 3200 pounds. Runs 8.35 in the 1/8 when deep staging at 81 mph and has a 1.78 60' time and a 5.32 330' time. .030 over 360 with a 9.5 to 1 compression ratio with Speed Pro cast pistons, stock crank and rods, factory windage tray, stock J heads with 1.88 and 1.60 valves, Comp Cams 262/270 Extreme Energy hydraylic cam with .462/.470 lift, Edelbrock Performer RPM intake with a 600 Holley double-pumper carburetor, Flo-Tech 1 /8 x 3 inch headers with 2 1/2" exhaust with H-pipe crossover and Flowmaster mufflers. Super stock leaf springs and adjustable pinion snubber, Lakewood 90/10 and 50/50 shocks, 904 transmission with the low gear set and a TCI 4200 stall converter. I have a set of Hoosier 29 x 10" slicks mounted on a set of 15 x 8 inch rallye wheels. I stall it to 2400 and shift at 5300 and run it through the 1/8th mile in 2nd gear. It will run a few tenths faster when regular staging it and no extra weight in the trunk and less fuel in the tank.
